Uneven curb height 1995 Del sol
Old Sep 26, 2005 | 10:57 AM
Qurz's Avatar
Default Uneven curb height 1995 Del sol
Well problem is i recently bought a lowered 95 s model, The right rear Fender sits an inch higher than the left rear, I thought it could be the springs but now i am on my 3rd set of new drop springs, and still the problem exists. I replaced the Lower and uppper control arms, springs, shocks. Could it possibly be my trailing arm bushings? or Frame damage? Because right now its not an issue, except Visually. No abnormal tire wear or anything else. Any ideas?
Old Sep 26, 2005 | 12:24 PM
dumped_ej1
Guest
Posts: n/a
Default Re: Uneven curb height 1995 Del sol (Qurz)
thats weird man.....did it have a salvaged title?
Old Sep 26, 2005 | 01:05 PM
Qurz's Avatar
Default Re: Uneven curb height 1995 Del sol (dumped_ej1)
Nope clear title, clean carfax.
Old Sep 26, 2005 | 01:12 PM
nocturnaldragon's Avatar
You do have the right springs on from the front to the back right? I know the rears are different and all that. Also try pushing the car down a few times in the front, Whenever I jack mine up in the front like that the nose site higher then normal untill I bounce it a few times to get it all to settle back into place so to speak.
Old Sep 26, 2005 | 01:29 PM
Turbo_y8's Avatar
Default Re: Uneven curb height 1995 Del sol (nocturnaldragon)
check your strut nut on the side that sits higher, mine did this i played with it and took off both strut assemblies and inspected them and the only diff. between them was the strut nut, ine wasnt as far do as the other tightened it a little more and fixed my problem
Old Sep 26, 2005 | 02:36 PM
Qurz's Avatar
Default Re: Uneven curb height 1995 Del sol (tuck'd98)
Yes, the correct springs are in the rear. The only wheel well that is higher than the others is the right rear. As for the strut bolt ill look into that tomorrow since its raining. Thanks for the replys.
Mats_A_G
Suspension & Brakes
Nov 2, 2012 03:42 PM
screamindolphin2
Oct 9, 2007 11:11 AM
JDMFantasy2k
Suspension & Brakes
11
May 25, 2006 11:00 PM
matthevelli
Suspension & Brakes
Mar 9, 2005 02:58 PM
flippedoutasian
Oct 12, 2003 09:16 PM
