FS Make an offer sale on all crx si parts everything must go and rotas, azenis
CALL 814-592-6640
make an offer on anything, chances are i will take it. i need cash and space for my new hatch project make an offer on anything you want i will probly take it. everything listed is off a 89 crx si
si black dash.
washer fluid bottle.
ecu cover.
( ELECTRIC DOOR HANDLES)complete door handle setup inside and out all linkage and electric acutators.. will need lock switch.....$15( for everything
manual steering rack..
tilt steering wheel column.
front sway bar...
5speed pedal cluster..
front tie rods........
heater control box (i dont have the heater control just have the box with flaps).
ac evaporator and box.
si exhaust manifold...
rear quarter interior window trim (black).
stock crx honda equalizer( with fitting bezel)..
wiper linkage and motor.
under hood rain tray(front cowl)...
steering wheel..
sunroof molding strip (gray).
rear view mirror with seatbelt indicator.
sunvisors......
si speedo cable.
windshield wiper resivior with two pumps for rear wiper setup.
sunroof motor with wiring...
resistor box.
fuel rail
also have a set of 4 azenis on rota circut 8s for 450 picked up. azenis where used 4 times to auto cross and have 99% tred left rotas need repainted but no bends or curbage at all.
Modified by classciv at 2:11 AM 9/27/2005
si black dash.
ecu cover.
front sway bar...
steering wheel..
sunvisors......
si speedo cable.
resistor box.
fuel rail
classciv
Sep 25, 2005 08:22 AM
classciv
Aug 4, 2005 12:20 PM
