? about Irridium NGK Plugs
Old Sep 26, 2005 | 09:42 AM
Chillinit's Avatar
Default ? about Irridium NGK Plugs
I'm was searching on the ngk website for a set of irridiums for my car and I came across two different plugs.
Motor spec : 1994 - 1.8 L - b18c1 (gsr)
1. IX Iridium - part number BKR6EIX-11 ($6.95)
2. Iridium plug part number IFR6E-11 ($11.74)
(link for reference)
http://www.ngk.com/results_app.asp?AAIA=1000359
My question is, does anyone know the difference between these plugs?
TIA
Old Sep 26, 2005 | 10:10 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: ? about Irridium NGK Plugs (Chillinit)
call ngk's tech line, they are very helpful
Old Sep 26, 2005 | 10:39 AM
-=Zeqs=-'s Avatar
Default Re: ? about Irridium NGK Plugs (PURPLETERROR)
I've used the IX plugs before and liked them quite a bit. Only drawback is...around 3000-5000 miles, my car felt weaker. Sure enough, changed the plugs back to resistors and it felt a little better. IMO...save the IX plugs for a dyno day or a track day. Don't expect them to last if you are going to daily drive them.
Old Sep 26, 2005 | 11:57 AM
Chillinit's Avatar
Default Re: ? about Irridium NGK Plugs (-=Zeqs=-)
up
Old Sep 26, 2005 | 06:38 PM
DEMNTD1's Avatar
Use part number BKR-6EIX-11. I used to use them as well and was happy with them, but have come to the conlusion that I can get V-Power plugs at a little over $2 each compared to about $7 each for the Iridiums.
I can change out the V- Power plugs about 3 times for the cost of one set of Iridiums.
Old Oct 24, 2005 | 10:00 PM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit &raquo;</TD></TR><TR><TD CLASS="quote">I'm was searching on the ngk website for a set of irridiums for my car and I came across two different plugs.
TIA</TD></TR></TABLE>
Taken from NGK's Web Site
IX Iridium Spark Plugs
Iridium IX Spark Plugs are the most technologically advanced high performance plugs available. Featuring a 0.6 mm iridium center electrode tip, they offer superior ignitability without sacrificing durability. The tapered ground electrode increases flame kernel expansion, while the superior heat range design is ideally suited to the demands of high performance environments. Specially designed to meet the needs of serious enthusiasts, Iridium IX Spark Plugs offer outstanding acceleration, high fuel efficiency and long life. When you demand the most from your engine, rely on the proven performance of NGK Iridium IX Spark Plugs.
Regular Iridium Spark Plugs
The next generation of spark plugs. NGK is a pioneer in Iridium Spark Plug design and manufacturing, and has been supplying Iridium Spark Plugs for Automotive OE since 1994.
* More Durability and a Higher Melting Point Than Platinum
* Better Center Electrode Anti-Oxidation and Anti-Erosion
* Improved Ignition
* Superior Anti-Fouling
* Lower Required Voltage
fryman
Apr 27, 2011 01:40 PM
i-VTEC_DOHC
Honda Civic (2006 - 2015)
10
Jan 24, 2010 09:05 PM
FlewByU352
Oct 20, 2009 07:49 PM
Bruce Banner
Sep 25, 2009 02:46 PM
PTownGSR
Jun 5, 2002 05:14 AM
