My first 1/4 Mile run! What should I expect?
Old Sep 26, 2005 | 09:11 AM
Modern91Hatch's Avatar
Default My first 1/4 Mile run! What should I expect?
I ran my very first 1/4 mile yeseterday:
15.2 @ 92.5 MPH
I had really bad wheel hop at the start. I must have sat there for 1 sec, hopping. I was expecting low 14s.
I didn't get a chance to run again, as the track closed early. See my setup in my sig.
I had Full throttle launch control set at 3700 rpm. Shifted at 8200 RPM.
What should I eventually expect when I get better at launching?
EDIT: I've got my slip, can anyone explain what it all means?
R/T ... .331
60 ... 2.575
330 ... 6.689
1/8 ... 10.015
MPH ... 73.98
1000 ... 12.859
1/4 ... 15.285
MPH ... 92.63
Modified by Modern91Hatch at 3:27 PM 9/26/2005
Old Sep 26, 2005 | 09:19 AM
ChronoEF's Avatar
What did your 60 ft. times look like?
Old Sep 26, 2005 | 09:23 AM
DohcVtecCrx's Avatar
Default Re: (ChronoEF)
were did you run? boise?
Old Sep 26, 2005 | 09:50 AM
FlatlineEF9's Avatar
Default Re: (DohcVtecCrx)
You should see about a 15 flat. in your sig is that all the mods you have?
Old Sep 26, 2005 | 10:04 AM
g-ride-si's Avatar
Is it just me or is a 3700rpm launch kind of low? I think if you get that up a little it will take care of some of the wheel hop. Post this in the drag racing forum and they should be able to help you. 60ft time would help too.
Old Sep 26, 2005 | 11:01 AM
I ran in Firebird in Boise. I don't remember my 60ft. My slip is at home. My R/T was .331. Is that included in the 15.2 sec? So my real time would be 14.9 if I reacted instantly?
Old Sep 26, 2005 | 11:04 AM
user 98292739's Avatar
ok i see the "super E-Ram" wtf man? its a frecking marine fan....**** it probally slows down air flow more then helps it.
Old Sep 26, 2005 | 11:06 AM
Default Re: (FlatlineEF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatlineEF9 &raquo;</TD></TR><TR><TD CLASS="quote">You should see about a 15 flat. in your sig is that all the mods you have?</TD></TR></TABLE>
This what I have:
B16a SIR2 (170 stock)
OBD 1 chipped with Stock P30 map + Vtec at 5300 RPM + Launch control @ 3700.
2 1/4 Exhaust with test pipe, 22' Resonator, Magnaflow Universal muffler
8.7 lbs fly wheel
Stock clutch
Cheap CAI(2.5 piping) with cheap eBay filter
11.3 Compression
11k Rated valve springs with Ti retainer
External MSD Ignition coil
Mild port job
4.400 Final dive 92' YS1 Tranny(short gear version)
Stock Cams
92 Octane Pump gas
Old Sep 26, 2005 | 11:27 AM
Default Re: (Rexified)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rexified &raquo;</TD></TR><TR><TD CLASS="quote">ok i see the "super E-Ram" wtf man? its a frecking marine fan....**** it probally slows down air flow more then helps it.</TD></TR></TABLE>
Super E-Ram is from: http://www.electricsupercharger.com/
Many racers and reliable resources say that they are the only good electric supercharger avaliable. The rest are what you described, cheap marine fans. Check them out, you'll be impressed.
Old Sep 26, 2005 | 12:06 PM
steronz's Avatar
Default Re: (Modern91Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Modern91Hatch &raquo;</TD></TR><TR><TD CLASS="quote">I ran in Firebird in Boise. I don't remember my 60ft. My slip is at home. My R/T was .331. Is that included in the 15.2 sec? So my real time would be 14.9 if I reacted instantly?</TD></TR></TABLE>
no, R/T has nothing to do with it. we want to know your 60 foot time... it'll be on your timeslip, probably about 2.4 or 2.5 seconds. that'll give us a better indicator of how much you can shave off by improving your launch.
Old Sep 26, 2005 | 12:54 PM
Many racers and reliable resources say that they are the only good electric supercharger avaliable. The rest are what you described, cheap marine fans. Check them out, you'll be impressed.</TD></TR></TABLE>
You paid $600 bucks for 1.7 psi of boost from an electric fan?. psi means jack ****, cfm is what makes the diffrence. The cfm is prolly super low.
Old Sep 26, 2005 | 01:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcVtecCrx &raquo;</TD></TR><TR><TD CLASS="quote">You paid $600 bucks for 1.7 psi of boost from an electric fan?. psi means jack ****, cfm is what makes the diffrence. The cfm is prolly super low.</TD></TR></TABLE>
That electric super charger has enough CFM flow to support a 5.0 v8. I can't remember, but it's like 1400 CFM flow @ 1.7 PSI, and it take 1500w of power to drive(2 hp). Enough to hold me to 10K when I get my cams.
It also says "Soon", which means I have't bought it yet. I don't have 600 bucks in fun money.
Old Sep 26, 2005 | 01:20 PM
ok good save your $$$ 600 will go towards a nice turbo kit
Old Sep 26, 2005 | 01:29 PM
ZCHF's Avatar
It also says "Soon", which means I have't bought it yet. I don't have 600 bucks in fun money.</TD></TR></TABLE>
consider yourself lucky. You just saved 600 bucks. thats 600 you could put into a homemade turbo kit that actually gets you some hp.
BTW, my homemade turbo zc smoked b16's
14.0 @ 100 + lots of tire spin
Old Sep 26, 2005 | 01:37 PM
cmyrex's Avatar
Default Re: (ZCHF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZCHF &raquo;</TD></TR><TR><TD CLASS="quote">
14.0 @ 100 + lots of tire spin</TD></TR></TABLE>
I will vouche on that one i myself have the homemade tubo ZC. For the price of the eram you could have pieced together a nice turbo for your b. Whatever floats your boat i guess
Old Sep 26, 2005 | 02:17 PM
Default Re: (ZCHF)
I did have a DOHC ZC that I pulled out and replaced with my B16. I have a CRX HF I'm putting the ZC into.
Old Sep 26, 2005 | 02:20 PM
Default Re: (steronz)
I've got my slip! here's the Numebers. Can any explain what they all mean?
R/T ... .331
60 ... 2.575
330 ... 6.689
1/8 ... 10.015
MPH ... 73.98
1000 ... 12.859
1/4 ... 15.285
MPH ... 92.63
Old Sep 26, 2005 | 02:24 PM
Default Re: (cmyrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmyrex &raquo;</TD></TR><TR><TD CLASS="quote">
I will vouche on that one i myself have the homemade tubo ZC. For the price of the eram you could have pieced together a nice turbo for your b. Whatever floats your boat i guess</TD></TR></TABLE>
My goal is an All-Motor B16 into the low 13s/high 12s. Once I reach that goal, I'll then begin to turbo charge. I'm doing all this so I can learn how to do things, not to have a 'faster' car. I'm 'allowing' my self to cheat a bit and get an electric surper charger to reach this goal.
Old Sep 26, 2005 | 02:38 PM
ZCHF's Avatar
My goal is an All-Motor B16 into the low 13s/high 12s. Once I reach that goal, I'll then begin to turbo charge. I'm doing all this so I can learn how to do things, not to have a 'faster' car. I'm 'allowing' my self to cheat a bit and get an electric surper charger to reach this goal.</TD></TR></TABLE>
I dont think those two sentences belong together.
Old Sep 26, 2005 | 02:42 PM
Default Re: (ZCHF)
I know, I know. I you guys think I'm out of my mind tring to get my B16 to run High 12s All-Motor with full interor, but no sound system, let me know.
Old Sep 26, 2005 | 02:46 PM
well ur at 15.2 now, so get ready to spend some cash flow. 2.0 and some serious cams, head work ect. and a very good tuning system.
Your gonna have to put down around 200 WHP uncorrected.... yes ACTUAL WHP.
Old Sep 26, 2005 | 02:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcVtecCrx &raquo;</TD></TR><TR><TD CLASS="quote">well ur at 15.2 now, so get ready to spend some cash flow. 2.0 and some serious cams, head work ect. and a very good tuning system.
Your gonna have to put down around 200 WHP uncorrected.... yes ACTUAL WHP.</TD></TR></TABLE>
B16 will never make it? I have to go B18 and resleeving? You can get near 200 WHP from a 1.6, just have to rev the **** out of it with hot cams and alot of head work. I heard you could get almost 300 WHP from a 2.0 All Motor. What his face from TheOldOne.com did it.
Also that 15.2 is my first run. I plan on getting better at racing, by Praying to God... j/k. I'll be at the race track evey opertunity!
Old Sep 26, 2005 | 02:59 PM
Suck my DX's Avatar
a 12 second b16 hatch is not impossible....but it takes a lot more than a powerful motor...u need to learn how to properly launch and drive that car...with ur set-up u should be right around low 14....now i dont know what this bs is about ur electric supercharger....these things maybe give u a 2 hp increase on a STOCK motor...if u know anything about cars u will know that different cars have different demands...especially with a high output motor, that fan will probably end up choking it at high rpms...how high does a 5.0 mustang rev? 6k tops. u are talking about reving all the way up to 10k rpm..now if u think that a 5.0 at 6k flows the same amount of air as a 1.6 at 10k ur sadly mistaken....save ur money buy urself a good clutch and work from there...so far u have a pretty good set-up...u just need to work on getting the power to the ground...spend the 600 bux on a quality header..u will be much more satisfied...if u buy that fan u will probably end up throwing it against the wall after it adds like .4 seconds to ur E.T.
good luck
Old Sep 26, 2005 | 03:06 PM
4potnick's Avatar
look at the 60ft. Last time at the track with stock ls motor, ys1(gsr) ls 5th, 8# flywheel, header + exhaust. everything else stock even the air box.
60' 2.207
1/8 9.489
mph 74.38
1/4 14.759
mph 93.19
that is in a full interior, A/C, in a 89 hatch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Modern91Hatch &raquo;</TD></TR><TR><TD CLASS="quote">I've got my slip! here's the Numebers. Can any explain what they all mean?
R/T ... .331
60 ... 2.575
330 ... 6.689
1/8 ... 10.015
MPH ... 73.98
1000 ... 12.859
1/4 ... 15.285
MPH ... 92.63</TD></TR></TABLE>
Old Sep 26, 2005 | 03:18 PM
Default Re: (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">a 12 second b16 hatch is not impossible....but it takes a lot more than a powerful motor...u need to learn how to properly launch and drive that car...with ur set-up u should be right around low 14....now i dont know what this bs is about ur electric supercharger....these things maybe give u a 2 hp increase on a STOCK motor...if u know anything about cars u will know that different cars have different demands...especially with a high output motor, that fan will probably end up choking it at high rpms...how high does a 5.0 mustang rev? 6k tops. u are talking about reving all the way up to 10k rpm..now if u think that a 5.0 at 6k flows the same amount of air as a 1.6 at 10k ur sadly mistaken....save ur money buy urself a good clutch and work from there...so far u have a pretty good set-up...u just need to work on getting the power to the ground...spend the 600 bux on a quality header..u will be much more satisfied...if u buy that fan u will probably end up throwing it against the wall after it adds like .4 seconds to ur E.T.
good luck </TD></TR></TABLE>
Thanks for the info. I'll probably forget about the stupid e-Ram, unless anyone has anything good to say about them. Any suggestions how I can practice my launchs? At the track I only get to run onces ever 1.5 hrs, making it hard to remember how I screwed up.
