BREAST! Squealing from timing belt area
Old Sep 26, 2005 | 07:42 AM
dominate9's Avatar
Default BREAST! Squealing from timing belt area
My cam seal started leaking so I decided to replace it. I set the engine to TDC. Took off the valve cover. Took off the timing belt. Took off the cam gear. Replaced the seal. Installed the cam gear back and the timing belt. Adjusted the timing belt (3 teeth method). I cranked the car up and the oil leak stopped but now there is this extremely loud squealing noise coming from the timing belt side of the engine. It is constant. I have the upper timing belt cover removed and after about 3 minutes of the car idling, I see smoke raising from the lower timing belt cover. There are no oil leaks and no coolant leaks. I readjusted the timing belt twice and the problem is still there. Could I have tighten the cam gear too much? i don't see how that could be a problem but I can't think of anything else.
Old Sep 27, 2005 | 08:00 AM
dominate9's Avatar
umm....bump?
Old Sep 27, 2005 | 08:50 AM
Crazydave's Avatar
Default Re: (dominate9)
Check you timing belt install. Sounds like it is rubbing something. Check the tensioner and the cover
Old Sep 27, 2005 | 09:53 AM
JayDeMgsr's Avatar
Default Re: (Crazydave)
yea bro do what dominate9 said and check that tensioner... the way your describing it sounds like the tensioner is siezed or something...mabey a lil overtighten???
Old Sep 27, 2005 | 10:26 AM
dominate9's Avatar
The tensioner is a manual tensioner and I've tried it loose and tight...the noise is still there. And what do you think could be rubbing to cause a squealing noise?
Old Sep 28, 2005 | 09:43 AM
Crazydave's Avatar
probably the belt rubbing something... look to see where the dust is building up
Old Sep 28, 2005 | 10:59 AM
dwnthehatch's Avatar
Take off the lower tb cover. It sounds like something fell in there.
Old Sep 28, 2005 | 01:38 PM
Suck my DX's Avatar
Default Re: (dwnthehatch)
yeah man take off the lower tbelt cover and check out whats going on...if it rubbing somewhere enough to cause smoke that means that it is eventually gonna rub till the belt breaks...and that means bye bye valves...and maybe even worse, end up messing up ur piston or cylinder wall...fix the problem before the worst happens...if the car was not making the noise before u installed the tbelt its obvious that something happened during the install...are u sure u ordered the right size belt?
Old Sep 28, 2005 | 04:07 PM
dominate9's Avatar
I bit the bullet and tore everything down. Seems like I tightened the manual tensioner too much and forced the washer that I had separating the pullies into one of the pullies. So that squealing sound was metal to metal contact. Fortunately, it was a successful fix. Thanks guys.
LS_VTECteggy
Jun 11, 2010 01:34 PM
thebleek
15
Sep 15, 2008 04:06 PM
red_hondas
Aug 2, 2007 09:57 AM
integrasi
Oct 30, 2003 08:12 PM
ef8mugen
Oct 3, 2003 09:14 PM
