Turbo B17 coupe Dynod 200whp @9psi...
Hey i finally got my built swap in and turbod. Runs pretty damn strong cept for a few minor issues.
I think i have a hydrocrabon leak, and we ran the dyno runs on a dying dizzy so the ignition kept missing at high rpms and throwin the dyno results off. We had one good pull and I made 200whp/150 ft/lbs.
Pretty good for a dying dizzy and a hydrocarbon leak. We were running 9psi. I got it all tuned by steve sakai on hondata
to him he knwos way more than he should about that stuff
So i was wondering, with this setup in my ej1 coupe what do you think ill run 1/4mi? It takes a second to spool, but after that it pulls HARD. Also it seems like the gearing is short as hell cause i always end up in 50th goin 80 after like 2seconds. Its a 98 GSR tranny.
Any guesses on 1/4mi times? I dont want to run it until my hydrocarbon leak is addressed...
thanks
thanks
yeah check the thread in my profile we are getting a garage- if not itll be at RIT but post up in the thread so we know your comin!
any ideas on times for this car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">what the hell is a hydrocarbon leak?</TD></TR></TABLE>
^^ what he said????
^^ what he said????
basically exhuast gas mixing with coolant = headgasket leak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riciv97 »</TD></TR><TR><TD CLASS="quote">200whp should get u into the low 14s in a coupe.</TD></TR></TABLE>
prolly high 13's if you use slicks + race gas and dont suck on your launch
I wouldn't run it at the track until you work out the bugs. Every dyno is different, but those numbers are extremely low.
Built and b-series should equal more than 200hp! A friend of mine had a D16y8 and was running 8lbs and was putting down 208hp on the freaking hack!
Seems low to me! Fix everything and it should get better i hope
Dutch
Dutch
