Would a chipped CRANK PULLEY cause vibration at high rpm?
Old Sep 25, 2005 | 08:25 PM
JDM H22's Avatar
Default Would a chipped CRANK PULLEY cause vibration at high rpm?
Getting a lot of vibration, especially at high rpm. Could it be the chip in my crank pulley. Thanks (searching didnt really help this time)
Old Sep 25, 2005 | 09:29 PM
Combustion Contraption's Avatar
If youve ever balanced a set of tires and wheels youd know this one.
Yes, a small chip can do ALOT at high RPM.
Old Sep 26, 2005 | 07:38 AM
nasteboyii's Avatar
Default Re: Would a chipped CRANK PULLEY cause vibration at high rpm? (JDM H22)
harmonic balances are not good, that is to say, any time u rev car it needs to be perfectly balanced the higher RPM u go the worst the balance will be to bearings/crank which is not good
get a new one
d
Old Sep 26, 2005 | 12:15 PM
h22atchturbo's Avatar
Default Re: Would a chipped CRANK PULLEY cause vibration at high rpm? (nasteboyii)
Just wondering is your motor an h series ? If it is the balance shafts belt must be installed correctlly.you will definetlly vibrate at higher rpms.you mostlly feal it in your foot.
Old Sep 26, 2005 | 06:07 PM
jdmd15bhatch's Avatar
Default Re: Would a chipped CRANK PULLEY cause vibration at high rpm? (h22atchturbo)
my old da integra had a mean chip out of the crank pully but it never rattled or viberated. as a matter of fact it still has the same crank pully on it and the new owner drives the hell out of it. neither of us have had any probs out of it.
Old Sep 26, 2005 | 07:45 PM
JDM H22's Avatar
This is a H22. The balance shaft has never been touched to my knowledge. It is swaped into an Accord. How often do those things go bad? Is it routine maintance to change it like a timming belt?
Old Sep 26, 2005 | 11:13 PM
Icey112's Avatar
i have a fully built gsr and my crank pully has a little pice missing out of it. run strong no vibrations.
Old Sep 28, 2005 | 05:31 PM
JDM H22's Avatar
Well some people say yes, others no. It seems to me that it would make a difference. What about the balance shaft belt. Would you know for sure if something went wrong there? The car is fine until 6000 rpm. Any more feedback or suggestions?
Old Sep 28, 2005 | 05:53 PM
Default Re: Would a chipped CRANK PULLEY cause vibration at high rpm? (Icey112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Icey112 &raquo;</TD></TR><TR><TD CLASS="quote">i have a fully built gsr and my crank pully has a little pice missing out of it. run strong no vibrations.</TD></TR></TABLE>
You have tested it with a load on it?
Old Sep 28, 2005 | 10:23 PM
Icey112's Avatar
Default Re: Would a chipped CRANK PULLEY cause vibration at high rpm? (LsVtec92Hatch)
with a load on it?
Old Sep 29, 2005 | 04:44 AM
LSVTEC 91 Civic's Avatar
Banned
The Main bearings sure as hell won't enjoy that pulley...
Old Sep 29, 2005 | 07:23 AM
mmuller's Avatar
Mad Scientist
Default Re: (LSVT3K 91 C1V1C)
yeah...it would not create vibration...
the ones who would take the hit would the the main bearings though. As LSVT3K 91 C1V1C sayd
****.. over tightening your belts will **** bearings up..
lakai_19
Sep 28, 2006 02:05 PM
95dcsleeper
Sep 5, 2005 06:48 PM
Def
36
Sep 4, 2003 06:26 PM
3700 Vtec
Jan 21, 2003 05:55 PM
Turbolude
Sep 12, 2001 05:53 PM
