engine damper? effectiveness?
Old Sep 25, 2005 | 08:04 PM
turbotime's Avatar
Default engine damper? effectiveness?
I have a b17 swapped into a civic and turboed. When it revs high the engine moves quite a bit. All the mounts are good, they are stock but not worn out or anything.
I was wondering if an engine damper would help reduce the forward/backward movement that occurs on acceleration and shifting?
thanks for any advice
Old Sep 25, 2005 | 08:30 PM
chinese acrobat's Avatar
Ive heard it will absorb some shock but will remain a little jumpy. Keep asking around on buildups
Old Sep 25, 2005 | 08:55 PM
turbotime's Avatar
do you think the stock mounts will break? I mean are they designed to flex that much?
Old Sep 25, 2005 | 08:57 PM
G2 Speed's Avatar
Default Re: (turbotime)
sure they can break.. engine dampners work vary well..... but... your car will rattle like a bitch
Old Sep 25, 2005 | 08:58 PM
turbotime's Avatar
well i know the aftermarket mounts make it rattle like a bitch too...
you really think the adjustable piston-stytle damper will make the car rattle real bad? then engine doesnt vibrate at all right now, it just kinda moves under acceleration due to the torque u know...
Old Sep 25, 2005 | 09:06 PM
G2 Speed's Avatar
I think i was wrong..
Greatly improved off-the-line acceleration
Reduced wheel hop
Improved vehicle stability
Reduced shock loads on driveline components
Smoother shifting
Reduced wear on exhaust system joints
Less vibration transmission to the driver compared to polyurethane motor mounts.
Less shock load, compared to torque straps and chains.
Drifting – helps reduce shock loads when wheels gain traction.
Reduces motor movement – decreases the chance of motor parts rubbing against the hood and frame.
Old Sep 25, 2005 | 11:25 PM
vsmhatched's Avatar
Default Re: (G2 Speed)
those motor mount inserts will help and their about 60 bucks or so.
Old Sep 26, 2005 | 01:52 AM
JDM Squad's Avatar
always wanted to get one for the bling/function, but someone keeps telling me it will rip/crack your frame or something. i dont know. what is inside of one? hard spring? some type of hard rubber?
Old Sep 26, 2005 | 05:16 AM
turbotime's Avatar
no its a piston
Old Sep 26, 2005 | 05:44 AM
mike1114's Avatar
get both, motor mount inserts and the engine damper.
I have the mounts but not the damper....yet.......
The mounts would help make the damper not ruin anything cause the motor will move less.
Old Sep 26, 2005 | 11:21 PM
JDM Squad's Avatar
Default Re: (mike1114)
its a piston? how does it work, does it compress air/grease/oil/ or something, very curious
Suare
Feb 13, 2012 06:03 PM
lil kid
Honda Civic (2001 - 2005)
Jul 22, 2008 02:11 AM
meno19
14
Aug 2, 2006 03:03 AM
Kryptonite
Feb 20, 2006 11:22 AM
pre92ludesi
Apr 16, 2002 05:47 PM
