Advantage Of Individual ........can't think of what it's called
Old Sep 25, 2005 | 07:00 PM
LSEGHATCH's Avatar
Default Advantage Of Individual ........can't think of what it's called
What is the advantage of using individual Spark Controllers (lol) vs. a dizzy?
Old Sep 25, 2005 | 08:52 PM
Combustion Contraption's Avatar
If each cylinder has its own coil, the coil has more time to recharge before firing again, vs one coil for all for cylinders. This makes a bit more top end power usually, and little bit better fuel economy down low.
Old Sep 25, 2005 | 08:56 PM
mmuller's Avatar
Mad Scientist
Default Re: (LsVtec92Hatch)
and ignition system reliability increases a lot.
Old Sep 26, 2005 | 06:39 AM
dfoxengr's Avatar
Default Re: (mmuller)
what is the easiest way to make an indiv. coil setup, and what kinda oem pieces could you source to make it?
are all motorcycle coils created equal?
also is there another options besides EMS to run it?
like cheaper....
im looking at this more for a fuel economy thing at this moment than a performance modification. not on my honda though.
BTW theres a good thread stickied in FI.
Old Sep 26, 2005 | 07:05 PM
LSEGHATCH's Avatar
Default Re: (dfoxengr)
What do you need to run in order for this setup to work? What is the average cost and are ther companies making these setups for honda's?
Old Sep 29, 2005 | 09:36 AM
dfoxengr's Avatar
Default Re: (LSEGHATCH)
the msd dist cap has a pin for one external coil. is there a way to make one with 4?
Old Sep 30, 2005 | 05:22 PM
dfoxengr's Avatar
anyone?
Old Oct 1, 2005 | 07:00 AM
non-VTEC's Avatar
the main advantage is that you can accurately control timing in each cylinder for fine tuning.
at higher rpm i heard that the stock distributor can "spark scatter" causing miss fires or inaccurate ignition timing to the cylinders.
you can get more voltage to each plug with individual coils.
those are the 3 things i can think of.......would you need something like that.........hell no.......the odd pro drag racer or someone who wants to make huge horsepower could probably utilize something like that.......for the average joe its a waste of money.
Old Oct 1, 2005 | 09:13 AM
mmuller's Avatar
Mad Scientist
over at pgmfi.org were trying to use individual coils with the stock ecu by using the cam position sensor; but no luck yet.
Old Oct 2, 2005 | 02:22 PM
dfoxengr's Avatar
what about my idea previously stated?
Old Oct 11, 2005 | 11:02 AM
dfoxengr's Avatar
anyone?
Old Oct 11, 2005 | 06:34 PM
NCchris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">anyone?</TD></TR></TABLE>
uh.... https://honda-tech.com/zerothread?id=1344468
HTH
chris
Old Oct 12, 2005 | 05:50 PM
dfoxengr's Avatar
Default Re: (NCchris)
uh...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">what is the easiest way to make an indiv. coil setup, and what kinda oem pieces could you source to make it?
like cheaper....
and
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">the msd dist cap has a pin for one external coil. is there a way to make one with 4?</TD></TR></TABLE>
that thread talks about aem ems....$$$$$$$$$$$$$$$$$$$$$$$$
and the comment in bold is about that thread.
Old Oct 15, 2005 | 07:16 AM
dfoxengr's Avatar
Old Oct 15, 2005 | 07:19 PM
b18ccivics's Avatar
power cost $$$$
Old Oct 15, 2005 | 07:21 PM
dfoxengr's Avatar
Default Re: (b18ccivics)
this isnt for power.
Old Oct 17, 2005 | 02:33 PM
dfoxengr's Avatar
any way to turn your stock distributor with a quasi msd-modded cap, but containing 4 coil outputs into a COP conversion?
Old Oct 17, 2005 | 03:09 PM
rainforest's Avatar
not sure about your idea but when i used sds i used coil packs and all you ned to do for that setup is a tone ring on the crankshaft to have a general idea of where the piston is at and when to enduce spark.
Old Oct 17, 2005 | 06:51 PM
dfoxengr's Avatar
Default Re: (rainforest)
sds?
tone ring?
care to explain what you did?
Old Oct 24, 2005 | 06:34 PM
dfoxengr's Avatar
Old Oct 25, 2005 | 05:39 PM
dfoxengr's Avatar
can anyone answer?
Old Oct 28, 2005 | 03:57 PM
dfoxengr's Avatar
im gonna keep bumping
Old Oct 28, 2005 | 05:59 PM
machine4321's Avatar
read here , all the info you need is here and also why it will and wont work
http://forum.pgmfi.org/viewtopic.php?t=5033
Old Nov 2, 2005 | 04:11 AM
dfoxengr's Avatar
Default Re: (machine4321)
"you must log in"
if theres a specific article, please copy/paste it
Old Nov 2, 2005 | 09:43 AM
Crazydave's Avatar
something like this:
