Can i use the block from a 93 teggy if it was underwater??
Old Sep 25, 2005 | 03:25 PM
seeeya04's Avatar
Default thanks
thanks
Modified by seeeya04 at 2:46 PM 9/27/2005
Old Sep 25, 2005 | 03:32 PM
Kendall's Avatar
Are you talking about just the block, or a complete shortblock?
Old Sep 25, 2005 | 03:37 PM
seeeya04's Avatar
Default Re: (Kendall)
Its the complete motor but iam just wanting the complete blcok from it
Old Sep 25, 2005 | 06:27 PM
seeeya04's Avatar
Default Re: Can i use the block from a 93 teggy if it was underwater?? (seeeya04)
buMP
Old Sep 25, 2005 | 07:31 PM
SOHCD16y8's Avatar
Did the motor fill with water?
Old Sep 25, 2005 | 07:46 PM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
Default Re: (SOHCD16y8)
Check block for holes and check the cylinder walls if its just the block.
Old Sep 26, 2005 | 04:54 PM
seeeya04's Avatar
Default Re: (.alex)
I went to pull the motor today and it had water in all pistons. and in the oil pan it was mixed water and oil. but the owner i know he said i can put some diesal fuel in the cylinder's and ect and it will eat all the rust if there is any up. ONly after i flushed the block ..
Old Sep 26, 2005 | 06:51 PM
adseguy's Avatar
Default Re: (seeeya04)
I'd be worried about rust on all bearing surfaces and also how did the engine die? Did it get waterlocked? You would basically have to rebuild the engine anyway, so I would get another block that blew rings or something for cheaper
KevinEF7
May 20, 2014 02:54 PM
lilmike
Mar 31, 2006 04:46 PM
jsull.
Oct 28, 2005 10:06 AM
jeremy.
Dec 15, 2003 04:49 PM
mr jun
Mar 11, 2003 03:49 AM
