What are the SYmPTOMS of a bad head gasket (gsr)
Old Sep 25, 2005 | 01:54 PM
Charlie Moua's Avatar
Default What are the SYmPTOMS of a bad head gasket (gsr)
I can't seem to remember how the heck to find out of the HG is bad on my GSR. Isn't one of the symptoms:
a) when you open radiator cap, bubbles keep coming out as you rev?
b) when you open up valve cover and oil mix with coolant causing a "milky" color coating?
thanks,...
Old Sep 25, 2005 | 01:55 PM
thaiphob's Avatar
Nikon!!!
Default Re: What are the SYmPTOMS of a bad head gasket (Charlie Moua)
Old Sep 25, 2005 | 01:58 PM
Lauj87's Avatar
or when you see oil in the coolent...and white some from tail pipe...
Old Sep 25, 2005 | 02:10 PM
Default Re: (Lauj87)
hum.... okay
well forsure there is no white smog from the tail pipe NOR do i see a mixture of oil detergents in my coolant.
thanks guys
Old Sep 25, 2005 | 04:16 PM
DrakeMK3's Avatar
Ok, having owned a MK3 supra for a long time (it's sold now) I've had my fair share of diagnosing headgasket problems. The symptoms of a blown headgasket are as follows:
Constant bubbles coming up in your coolant due to exhaust gases trying to escape.
Coolant in the oil causing the aforementioned milky coloration (it sorta looks like nasty chocolate milk)
Oil in the coolant that looks like mud.
White smoke coming out of the exhaust. This would be the case when a coolant jacket portion of the head gasket has broken allowing coolant into the combustion chamber.
Keep in mind, you may exhibit just one or perhaps all of these symptoms when dealing with a blown headgasket. Hope you find your problem.
xprohx
Apr 30, 2013 10:01 AM
DRoylflush
11
Apr 10, 2011 02:11 PM
futurefastguy
May 2, 2009 10:33 PM
crowder13
Nov 1, 2007 09:04 AM
blumpfish
Jun 18, 2006 09:23 PM
