Can disconected/broken VSS cause CEL......?
Old Sep 25, 2005 | 01:47 PM
Charlie Moua's Avatar
Default Can disconected/broken VSS cause CEL......?
i have a 91 civic hb with GSR swap & convered to hydro tranny & OBD1 with p72.
When i drove it the EF vss cable broke on me. I wanted to know if the VSS cable is broken or causing the Speedo not to work would that affect my p72 THROWING a cel or cause vtec not to work?
Thanks fells, I've been out of H-T for a while
Charlie Neng Moua
Old Sep 25, 2005 | 01:49 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Can disconected/broken VSS cause CEL......? (Charlie Moua)
yes, yes, and yes
Old Sep 25, 2005 | 01:54 PM
Mach69's Avatar
causes a code 17 which throws the ecu into limp mode and does not allow the vtec to engage.
Old Sep 25, 2005 | 01:56 PM
Default Re: Can disconected/broken VSS cause CEL......? (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">causes a code 17 which throws the ecu into limp mode and does not allow the vtec to engage.</TD></TR></TABLE>
I belive my ef speedo cable broke cause there was too much tension on the line. I was thinking about getting a DA one.
Q:
how much time should i allow myself to take out cluster/dash and re-install new DA cable?
stickman78114
Sep 10, 2012 09:20 AM
HondaMan2380
Mar 26, 2012 11:08 AM
crxdxsir
11
Nov 14, 2006 08:39 PM
ITR.#1446
Oct 18, 2005 06:49 PM
j_max420
10
Feb 23, 2005 09:11 AM
