springs or coilovers
Old Mar 1, 2002 | 04:14 PM
paulyman's Avatar
Default springs or coilovers
guys im not really very edjucated in suspension
maybe you can help me out.
i want to lower my car
i am keeping the stock rims and running 205/15 tires
should i go with like neuspeed springs
or like gc coilovers
i just want to eliminate my wheel well gap and get alittle lower
and for that sporty look.
can someone explain springs
when i put springs on i use my existing shocks right?
and i have heard talk about cracking bushings or something on the gc coil overs
well if some one can just tell me the difference between the two
and how installing springs is different that installing coilovers
that would be a help
thanks guys
Old Mar 1, 2002 | 07:06 PM
Tegman10's Avatar
Default Re: springs or coilovers (paulyman)
i got GC coilovers on my car and i love them, no problems, easy to adjust.
Old Mar 1, 2002 | 09:23 PM
RacingE_Teg's Avatar
Whenever you put lowering springs or coilover sleeves while using oem shocks, it will decrease the life expectancy of the shock.
Coilovers allow you to adjust the height of the car whenever you want, while the Neuspeed spring is just a spring and offers no adjustability.
Kind of vague, but hope you see the difference b/t the two types.
Old Mar 2, 2002 | 04:19 PM
paulyman's Avatar
Default Re: springs or coilovers (Tegman10)
did you put new shocks on your car
or did you use the stock ones
how much did your drop cost you with parts and labor
Old Mar 2, 2002 | 04:43 PM
Kellindal's Avatar
Default Re: springs or coilovers (RacingE_Teg)
Like he said, if you're going to put on new springs or coilovers, it's a good idea to switch out to new shocks or struts. Popular ones on the board are Koni Yellows (the most popular) also people like the Tokico Illuminas and the KYB AGX ( <- I think that's right). All are adjustable shocks for stiffness. So yeah, in conclusion, if you want to drop your car, it's safest to get new shocks as well.
BLeSR
May 7, 2010 12:33 AM
JrEk9
Suspension & Brakes
19
Nov 24, 2009 02:26 PM
Wonk Unit
Apr 19, 2006 03:46 PM
flamega
Mar 16, 2005 01:31 PM
#1sandman
Sep 1, 2004 12:23 PM
