cams,valves,pistons
Old Sep 25, 2005 | 09:45 AM
jaydeeumms's Avatar
Default cams,valves,pistons
hello... i posted earlier about getting the skunk stage 2 cams and the valve upgrade, i will also be getting some pistons along with the cams and what not. As of now i want to get the toda B-series forged piston set. The set includes 4 forged pistons, piston rings, clips, and wrist pins. It says that when combined with spec b or spec C cams, they give a noticable increase in power. Should i stick with the toda?... also are the skunk 2 stage 2 cams spec b or c?.... or should i just get toda cams along with the pistons?
Old Sep 26, 2005 | 01:36 PM
Rocket's Avatar
Default Re: cams,valves,pistons (jaydeeumms)
I like CP pistons along with alot of other people. My friend Brad (MAX_CFM) likes Wiseco.
A friend of mine once told me he felt the Toda specs for piston-to-wall clearance for their forged pistons was too tight for his liking.
Old Sep 29, 2005 | 08:52 PM
jaydeeumms's Avatar
Default Re: cams,valves,pistons (Rocket)
well thank you, but its ok, the problem is taken care of... i've decided to go with a turbo kit... boosted is the way im going i guess.... dont worry the built internals are coming too.
battle2.0ek9
Apr 27, 2007 05:01 PM
WH0R3nEF9
Jan 7, 2006 08:17 AM
PowerHouse
Apr 5, 2004 11:40 PM
K20 EG
Apr 25, 2003 09:51 AM
ITR111
Sep 30, 2001 01:37 PM
