noise after lower car
Old Sep 25, 2005 | 12:08 AM
happy_guy's Avatar
Default noise after lower car
i lowered my car today with lowering springs on stock shocks.. now when i go over bumps the rears go clunk.. is this normal?
Old Sep 25, 2005 | 02:35 AM
TimeAttackFreak's Avatar
Default Re: noise after lower car (happy_guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by happy_guy &raquo;</TD></TR><TR><TD CLASS="quote">i lowered my car today with lowering springs on stock shocks.. now when i go over bumps the rears go clunk.. is this normal?</TD></TR></TABLE>
Stock shocks =\ I don't know how low you are but stock shocks do not perform well due to the shorter shock travel.
What you are probably hearing is the rear suspension going full compression on the shock and that will kill the life of those things pretty soon. You might want to check the torque on all your suspension related parts to be sure they are with in the factory spec if your funds do not allow for a set of aftermarket shock absorbers. Hell just check the torque on them anyway, better to be safe than sorry.
Old Sep 25, 2005 | 03:13 AM
no2unenolife's Avatar
usually that noise can come from uncut bumpstops,
it is recommened you cut them inhalf!
Old Sep 25, 2005 | 07:57 AM
Yambor's Avatar
Default Re: (no2unenolife)
that or he is hearing the unactive springs clank together...
or maybe his stockies are blown or damn, maybe both..
Old Sep 25, 2005 | 09:05 PM
BrooX's Avatar
Awww dude that sucks, I just went through that with my DA, and I had blown a boot that is attached to the stock shocks. I know that it looks clean slammed, but there is a price to pay when you slam your ride....either way you should fix it asap, w/draw from the bank, borrow from a friend but do what you gotta do to fix it b-4 it becomes a real fucked up problem. Take my experience as a warning, and fix it Go to a local shop(or do it yourself if you have the knowledge) and order yourself a suspension setup such as Koni or Tein. Those are the two brands I recommend. I just had some Koni's w/adjustable coils put in my DA and ooohhh baby the ride quality is
Old Sep 25, 2005 | 09:11 PM
low430's Avatar
Hey No2uneolife Dont talk unless you know what your talking about..
DO NOT CUT THE BUMPSTOPS !!!!
Mentat Ghola
Dec 31, 2009 10:12 AM
andysila
Suspension & Brakes
Jul 21, 2006 11:04 AM
Davmx
Jan 16, 2005 08:21 PM
Campee
Oct 25, 2004 11:13 AM
98slvrcx
Jul 13, 2003 04:57 PM
