Drum's to Disc's
Old Sep 24, 2005 | 11:41 PM
Fixmycar's Avatar
Default Drum's to Disc's
I have a 2004 Civic SE and i am considering changing the rear drums to discs, so i have 4wheel discs.
What exactly would i need to make this possible?
Would i be able to rip the rear-end off a Acura 1.7EL and bolt it on?
Thanks for your help
Old Sep 25, 2005 | 05:15 AM
NciroM2003's Avatar
HT Black Ops
you can get parts off an early ep.
not whole rear end just from hub outward if im correct.
Old Sep 25, 2005 | 11:19 AM
mrDFWmechanic's Avatar
you'll need the hub along with the discs and rotors and calipers, plus you'll need the ebrake cables from an ep3. once you have all that it just bolts right up
Old Sep 25, 2005 | 02:49 PM
Boilermaker1's Avatar
Default Re: (02civic86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02civic86 &raquo;</TD></TR><TR><TD CLASS="quote">you can get parts off an early ep.
not whole rear end just from hub outward if im correct.</TD></TR></TABLE>
You need the entire knuckle assembly + ebrake cables and brake lines.
You can use EL parts or SIR parts. If you don't have ABS, you may/may not have a bias issue (I don't know because my car has ABS) but the knuckles bolt right up. Its a simple swap.
Since I don't know canadian models... if the SE is like a DX, yanking the EL control arms would also give you swaybar mounts.
Old Sep 26, 2005 | 04:54 AM
wako182774's Avatar
Default Re: (Boilermaker1)
Does anyone know what would be the general costs of parts alone coming from an ep3?
Old Sep 26, 2005 | 11:46 AM
i've seen the whole rear disk conversion go for around 200 - 250 on ebay
Old Sep 26, 2005 | 06:28 PM
NciroM2003's Avatar
HT Black Ops
dam, sounds good. i remember a few years ago it was averaged around 600 from a junkyard. 250 is dam good ill get me some
Old Sep 26, 2005 | 11:30 PM
Fixmycar's Avatar
Thanks for the help
Hope to get working on it soon
Whatislove
Honda Civic (2001 - 2005)
12
Nov 9, 2010 06:59 AM
UnKnOwNsLeEpEr
Jul 26, 2005 08:03 PM
mike93eh
Feb 8, 2004 12:32 AM
civic_to
Sep 28, 2003 08:33 PM
