LAUNCHING Preload? or Clutch DUmp?
Old Sep 24, 2005 | 08:49 PM
crxh22project's Avatar
Default LAUNCHING Preload? or Clutch DUmp?
I launch my crx with b16 at 5k i tried preloading today it seems pretty cool.
SHould i dump the clutch instead when launching or will I hook faster preloading?
I just want to launch hard.
Old Sep 24, 2005 | 08:51 PM
Redline130's Avatar
Default Re: LAUNCHING Preload? or Clutch DUmp? (crxh22project)
Preloading will help save your tranny.
Old Sep 24, 2005 | 08:58 PM
flip1199's Avatar
Default Re: LAUNCHING Preload? or Clutch DUmp? (Redline130)
preloadind is easier on drivetrain. i'd rather preload then break axels.
Old Sep 24, 2005 | 08:59 PM
mrbsponge's Avatar
when i was NA, i used to pretty much ride it for a sec, then dump it.
but now that im turbo, preloading is so much greater, because i can start to make boost and save my driveline
as far as NA i dont see much use for it
Old Sep 24, 2005 | 10:32 PM
Luserkid's Avatar
Default Re: (mrbsponge)
How exactly do you preload?
Old Sep 24, 2005 | 10:47 PM
z6's Avatar
z6
^slip it so there is already some force trying to drive the car, this way there wont be a big shock of torque when you take off
Old Sep 25, 2005 | 01:33 AM
hondaguyef's Avatar
Default Re: (z6)
Preload>Dump for sure. Nuff said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">How exactly do you preload? </TD></TR></TABLE>
While in the pre stage, With the e-brake up (button pushed in/removed) Let the clutch out just enough to where it feels as if the car wants to pull forward. Set your Launch RPM. "Pump" the car forward by letting the E-brake up/down slightly until you're staged. When you feel it's go time let the e-brake down in the same motion the clutch is being released.
Phil
Old Sep 25, 2005 | 08:52 AM
Luserkid's Avatar
Default Re: (hondaguyef)
Thanks, im going to have to try that next time
Old Sep 25, 2005 | 11:49 AM
dome's Avatar
Default Re: (Luserkid)
put line locks on the back wheels and hook it to a button on your stearing wheel. have your 2 step hooked to the button too. let the clutch out 3/4 of the way and mash the gas. the just let the button go
Old Sep 25, 2005 | 11:53 AM
flip1199's Avatar
Default Re: (dome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dome &raquo;</TD></TR><TR><TD CLASS="quote">put line locks on the back wheels and hook it to a button on your stearing wheel. have your 2 step hooked to the button too. let the clutch out 3/4 of the way and mash the gas. the just let the button go </TD></TR></TABLE>
Are line locks legal for all classes? sfwd/t4?
Old Sep 25, 2005 | 12:19 PM
Default Re: (flip1199)
So is preload really necessary for N/A set up.
It seems that Turbo people like cause of the boost build for a N/A is really neccesary
Old Sep 25, 2005 | 12:55 PM
hondaguyef's Avatar
Default Re: (crxh22project)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxh22project &raquo;</TD></TR><TR><TD CLASS="quote">So is preload really necessary for N/A set up.
It seems that Turbo people like cause of the boost build for a N/A is really neccesary</TD></TR></TABLE>
It's necessary to save/extend life of drivetrain components.
STEVE-O7
Oct 10, 2007 05:18 PM
wicked2night
Apr 4, 2007 10:30 PM
nk2k2
Oct 11, 2006 12:50 PM
BigC-ivic
Apr 23, 2005 07:34 AM
Hehehe I just
Nov 24, 2003 12:05 AM
