Need Cat For Greddy
Old Sep 24, 2005 | 04:27 PM
badbway14's Avatar
Default Need Cat For Greddy
I just got my Si and was installing my Greddy EVO II, I noticed the cat was broken so I need a replacement. Any recommendations (Carsound, EVO)? Do I need a 2.25 or 2.5 Cat?
Old Sep 24, 2005 | 04:34 PM
RedEj8's Avatar
Default Re: Need Cat For Greddy (badbway14)
U need a 2.25 inch cat. I would just run a test pipe ($20 ebay cat) or get one custom made. I have a jackson racing hi-flow cat and its alrite.
Old Sep 24, 2005 | 06:56 PM
nota-eg's Avatar
Default Re: Need Cat For Greddy (reddohcvtec)
If you're NA don't get a testpipe. It's bad for low-end.
If anything get a high-flow. Flowmaster also makes them.
Old Sep 24, 2005 | 08:28 PM
C2daIzZle's Avatar
carsound is a decent cat to use. i noticed your in florida.. so i google'd to see if fl had emissions & smog.. they do, so if you run a ebay testpipe suggested above.. then i hope you know someone to slide your car threw emissions otherwise you will NOT pass the NOx & CO count on your cars emissions will be waaaaay to high, just thought thou. carsound is a good, smog'able cat, not to expensive either. anyway carsound is the way to go imo.
Old Sep 24, 2005 | 09:08 PM
civic_driver's Avatar
get unversal and have your local muffler shop weld flanges on it... or if you have a welder just weld them yourself... universal cat = $50.... flanged cat specific to your car=$150+
you can get flanges cheap and if you need to extend the cat, you can weld an extension pipe to fit the "cat space"
JDM00SI
Oct 15, 2005 09:14 PM
miro_gt
Sep 12, 2005 07:51 PM
shhh151
Aug 4, 2004 02:32 PM
Audio28
Nov 16, 2002 03:38 PM
MooreBoost
Jul 30, 2002 02:35 PM
