95 GSR gauge cluster into a rex (91)?
Old Sep 24, 2005 | 02:55 PM
crxsir07's Avatar
Default 95 GSR gauge cluster into a rex (91)?
Alright guys, I have seen 99 si clusters in the rexs, and Teggy clusters they both look Sick, so I went out to the boneyard and got an Electronic speed sensor, and got a GSR cluster off Ebay for 65bucks! on http://www.EF-Honda.com they have a good tech article on the Si cluster,
but I'm not sure if the wiring is the same for the DC2 wiring, and i'm sure the clips are different, so, Where could I find the right clips for the back of the cluster? ( i already have the two smaller ones ( green, and yellow) and Is the wiring the same as the 99 SI's or is it different? I just want to know so i have everything I nned when I go to put it in Thanks for any help!!!!!
Old Sep 26, 2005 | 04:41 AM
crxsir07's Avatar
Default Re: 95 GSR gauge cluster into a rex (91)? (crxsir07)
bump, anybody know more about this swap?
Old Sep 26, 2005 | 05:15 AM
Mr Synister's Avatar
Default Re: 95 GSR gauge cluster into a rex (crxsir07)
here you go
https://honda-tech.com/zerothread?id=991363
as for what clips you need the 2 of the one's in the back of the cluster. forget about the green and yellow ones. and as for the wiring the pins are different from the civic's but you can use the same clips just repin them to work properly with the integra cluster.
Old Sep 27, 2005 | 07:38 AM
crxsir07's Avatar
Default Re: 95 GSR gauge cluster into a rex (Mr Synister)
Hey thanks man!
Old Sep 27, 2005 | 09:47 AM
The DX Rex's Avatar
ef8ryder90
Nov 1, 2006 12:38 PM
civic_hatchy
Dec 13, 2004 03:48 PM
japrex
Nov 21, 2004 07:22 PM
Sean EH2
May 25, 2003 05:15 PM
JDM88EF9
12
Sep 11, 2002 06:08 PM
