heat problem
Old Sep 24, 2005 | 01:58 PM
ROCsFinest's Avatar
Default heat problem
as i was turning the **** from cold to heat, it felt like it was stuck on something so i gave it a little more "umph" and then i heard something snap. NOW, my heat doesnt work. any ideas on what i did?
Old Sep 24, 2005 | 02:22 PM
P_Adams's Avatar
Default Re: heat problem (ROCsFinest)
Broke the ****
Broke the shaft
Broke the gear
Broke the lever
Broke the cable
I've no idea what car
I've no idea what year
I've no idea what model
Pick one, I can't
P
Old Sep 24, 2005 | 02:56 PM
as_fast_as_u's Avatar
prolly broke your switch itself.......pullout your console and unplug the plug that you broke...go to the junkyard or dealer and get a new one...on some models the price from the dealer might b expensive since the heat **** is on the same platform with all the other switches( like your A/C, fan etc) Junk yard is your best bet
Old Sep 24, 2005 | 04:19 PM
The Maryland Truth's Avatar
If your lucky it just the heater control **** that broke those are fairly cheap brand new from the dealership it is like 11 bucks
Old Sep 24, 2005 | 04:34 PM
hondadude's Avatar
this is a common problem on your 1958 civic
Old Sep 24, 2005 | 07:02 PM
deserthonda's Avatar
Default Re: heat problem (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">this is a common problem on your 1958 civic</TD></TR></TABLE>
it could also be the knobulator spring that came off.......
Old Sep 24, 2005 | 07:07 PM
BLKFLSH's Avatar
Turn the **** over, stick a small screwdriver in the shaft hole and pry on it just to see if you have a crack in it. I've broken a couple of them before I learned. Don't put too much pressure on the ****, turn it about halfway or until you feel tension, then let it sit for a couple of seconds, it will loosen up, then you can turn it the rest of the way. That or try to lube the cable so it will slide easier or get a new cable. I think turning it with a gentle touch is easier than changing the cable or trying to lube it up.
Old Sep 25, 2005 | 09:12 AM
ROCsFinest's Avatar
appriciate the quick responses.
97 accord ex
Old Sep 28, 2005 | 10:50 AM
ROCsFinest's Avatar
so i messed around with the cable and the heat now works. BUT, i have a new question now...
how do i get to where i can get cold air and heat blowing at the same time so i dont have to keep messing with the cable? (like a default position)
Old Sep 29, 2005 | 09:14 AM
ROCsFinest's Avatar
bump
neli_nael
Jan 30, 2009 02:55 PM
dbbyleo
May 24, 2007 08:39 AM
b18c-1
Feb 10, 2007 10:13 PM
1992AccordEX
Aug 19, 2005 10:39 AM
1992AccordEX
Aug 7, 2005 10:26 AM
