Cost to replace master cylinder and brake pads?
I have a 1996 Honda Accord EX (4 cyl), w/ ABS; 127,000 miles. My brakes were failing and I paid to have the master cylinder and rear brake pads replaced. Costs were $350 for cylinder plus $108 labor; $61 for rear pads and resuface rear rotors plus $144 for labor---total was $720.
I can't find a quote for a new master brake cylinder for my make/model w/ ABS (even OEM from Honda dealership), over $140. Most new cylinders were between $90 and $125.
Was I gouged (they knew I couldn't drive the car, unsafe brakes)? Does anyone know actual costs (part/labor) for replacing cylinder in 1996 Honda Accord?
Thank you. Karen
Thank you. Karen
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kep »</TD></TR><TR><TD CLASS="quote">I have a 1996 Honda Accord EX (4 cyl), w/ ABS; 127,000 miles. My brakes were failing and I paid to have the master cylinder and rear brake pads replaced. Costs were $350 for cylinder plus $108 labor; $61 for rear pads and resuface rear rotors plus $144 for labor---total was $720.
Thank you. Karen</TD></TR></TABLE>
Karen listen carefully.........the master from a dealer is no more than 125 dollars labor to install should be no more than 60-100 dollars brake fluid around 3-5 dollars..........the price for rear pads and resurface rotors sounds in the ball park....first off get a quote, written if possible from a dealer on a brake master then .....get ur receipt and go back to the shop and ask WHY u got charged soooooooo much for the master cylinder and DEMAND some money back or else....
wat???? where u get all the cheap price??? i ask several places around southern cali and wit ABS is around 250-300... and w/o abs is 150 oem....
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtran002 »</TD></TR><TR><TD CLASS="quote">wat???? where u get all the cheap price??? i ask several places around southern cali and wit ABS is around 250-300... and w/o abs is 150 oem....</TD></TR></TABLE>
http://www.tasauto.com genuine honda master cylinder with ABS is around 130 on there
here in arizona the price is the same with or without abs it is around 133 dollars and YES from the DEALER that is the only ones i will install on my customer cars ...and down here because of the heat in the summer time we avarege anywhere from 3 to 6 per month ,,so i know the prices , i pay the bill.....
Wow... I feel really sorry to read that!!!
I think you should consider hireing a lawyer to get your money, or at least, a descent part of it back!!!
Thanks for your input/support. I called them on it; they claimed they were merely passing along the "list price" quoted by their parts supplier. But they returned $238 to me, took out the other part; installed the Honda OEM cylinder (I called the dealership to confirm they'd sold them one w/in the past day; made them show me the receipt for it at the garage).
So, they're either deceitful or clueless, regardless, it pays to stand up for yourself and I won't be going back. One for the small guy/girl.
Thanks again.
Thanks again.
I paid $90 at O'Reily Auto Parts with a $30 core charge for a master cylinder for my 94 with ABS,and about $45 for some Satisfied ceramic pads from Advance Auto Parts.Did it myself in about an hour and a half.There's no reason an ABS master cylinder should be more expensive than a non ABS unit for the 94-97 Accord,the only difference is the diameter of the lines,if I'm not mistaken.NEVER go to a dealer unless it's absolutely necessary (or your car is under warranty) and the parts/labor can't be sourced from elsewhere.I should know;I work at a dealership
I am glad, I am so glad you stood up for yourself and got YOUR money back!!!
People do take advantage of other people at any chance they have.....
Good... you did good!!!
...and i'm a guy btw....lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona »</TD></TR><TR><TD CLASS="quote">good for you!
1 for the little guy/girl, 0 for incompetent dealers</TD></TR></TABLE>
well actually to be fair it would actually be 1 for the little guy/girl 549875439086093287695827629875684576487528 for incompetent dealers.
Demigod2019
Jun 24, 2019 03:17 PM
CDStreetSleeper
Mar 8, 2013 06:53 AM
dailydrivenHONDA
Jun 8, 2009 01:16 PM
