Coverting to OBD1
Old Sep 24, 2005 | 01:20 PM
Conclusive's Avatar
Default Coverting to OBD1
Got the d16z6 in and is currently obd-0. What do I need to buy to go to obd-1?
Already have the distributor, getting a p28 ecu tonight.
What else and where to get it fast?
Thanks
Old Sep 24, 2005 | 02:12 PM
Mach69's Avatar
Default Re: Coverting to OBD1 (Conclusive)
4 wire O2 sensor, conversion harness.
edit: rywire.com
Old Sep 24, 2005 | 02:52 PM
f@sth@tch89's Avatar
Default Re: Coverting to OBD1 (Mach69)
BUMP
IM DOING THE SAME FOR MY ef drag HATCH W/ A B20VTEC....
im converting my entire car and will hack the stock harness of all the unneccessary stuff i don't need later.
i looking to get dash/engine harness, both fuse boxes, obd-1 dizzy, p28, main relay and i think that may be all i need. if im missing something...someone chime in and let me know.
Old Sep 24, 2005 | 03:38 PM
Conclusive's Avatar
edit: rywire.com
Do I have to send those guys my old harness? It's already hacked and in the car.
Thanks.
Old Sep 24, 2005 | 04:02 PM
user 98292739's Avatar
no buy the kit its about 190 bucks and it includes all the subharnesss and ecu converter. also includes dizzy plug conversion. i got it well worth it.
Old Sep 24, 2005 | 05:00 PM
Blown90hatcH's Avatar
Default Re: (Rexified)
http://www.Rywire.com
http://www.JKOBD.com
4 wire O2 sensor, OBD1 ecu, OBD1/2 distributor and the conversion harness. You can run any injectors you want. Pre-OBD (OBD0) run the resistor box. OBD1/2 remove it and solder the 5 wires together.
Jason
http://www.JKObd.com
Old Sep 24, 2005 | 08:20 PM
Rywire's Avatar
Default Re: (Blown90hatcH)
You need to send your harness only if its a dpfi car...
si90rex
11
Feb 1, 2013 07:40 PM
puertoroc7976
Oct 10, 2006 05:19 PM
Fezzie
Aug 31, 2006 05:40 AM
mrx
Mar 12, 2005 01:06 PM
Blown90hatcH
77
Feb 16, 2002 04:18 PM
