does open header cause higher idle?
Old Sep 24, 2005 | 01:18 PM
Kyles ej1's Avatar
Default does open header cause higher idle?
i just dropped an ls in my eg last night and the cat doesnt bolt up to the b pipe so im running opne header....kinda....it has the cat on. but yea it idles at like 1000, is that normal for open header?
Old Sep 24, 2005 | 01:22 PM
RedSI93's Avatar
Default Re: does open header cause higher idle? (93ejay1)
Im not sure, im having like the same problem...but its more like betwen 1000- 1500...and when it gets warm i get an idle surge, im lookin for the answers myself. this is an ls in a 93 si hatch...the ls was in my crx and it ran fine. where are the answers??
Old Sep 24, 2005 | 01:35 PM
ThatsMyEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 &raquo;</TD></TR><TR><TD CLASS="quote">i just dropped an ls in my eg last night and the cat doesnt bolt up to the b pipe so im running opne header....kinda....it has the cat on. but yea it idles at like 1000, is that normal for open header?</TD></TR></TABLE>yes.
Old Sep 24, 2005 | 01:40 PM
JDM-EJ1's Avatar
Default Re: does open header cause higher idle? (ThatsMyEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatsMyEG &raquo;</TD></TR><TR><TD CLASS="quote">yes.</TD></TR></TABLE>
Why does it idle higher? That's a weak answer.
On a side note, running open header is a great way to bend a valve. I would suggest getting a header on your car, or refrain from driving it ASAP.
Old Sep 24, 2005 | 01:58 PM
1995Ex_Sedan's Avatar
Default Re: does open header cause higher idle? (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
On a side note, running open header is a great way to bend a valve. I would suggest getting a header on your car, or refrain from driving it ASAP.</TD></TR></TABLE>
Thats what I was going to mention. Open header allows cool air to get to the engine alot faster.
Old Sep 24, 2005 | 02:04 PM
kaoss_11's Avatar
B A N N E D
i would like to see proof of this because i did for a while in one of my old projects for almost a year and even raced open header. No idle issues or bent valves
Old Sep 24, 2005 | 02:11 PM
ThatsMyEG's Avatar
I know on all my drag cars I've run open header, and have never had a problem. The reason it idles higher is because there's no exhaust piping, cat or a muffler restraining pressure when you disconnect your header its cause the engine pressure to flow better. which im not saying its a good idea to run a open header, but it will not hurt your car with a stock setup..
Modified by ThatsMyEG at 3:42 PM 9/24/2005
Old Sep 24, 2005 | 02:29 PM
Kyles ej1's Avatar
im only doing it till i figure out how to get my exhaust working cuz if you read my post i dropped an ls in my eg and the cat is like 1 inch short of the b pipe
Benhawk
Apr 1, 2007 10:18 AM
S2KILLA
Oct 26, 2005 10:36 AM
iperez
Apr 3, 2004 05:21 AM
Aaron M
Aug 30, 2003 11:26 AM
BlueIntegraBoy
Aug 16, 2003 08:44 AM
