enigne swap from hell...
Old Sep 24, 2005 | 12:56 PM
NA EJ1's Avatar
Default enigne swap from hell...
motor: 00 civic EX
car: 94 civic EX
using OBD1 harness from the 94, P28 ecu, swapped internals from obd1 EX distributor, rewired harness for OBD2 injectors
problem: misfire cylinders 1 & 2...backfires and cuts off...code 14 for IAC
any help is much needed and appreciated...TIA
Old Sep 24, 2005 | 03:24 PM
BuddhaSiR's Avatar
Default Re: enigne swap from hell... (NA EJ1)
check your firing order on your dizzy as this can be easily overlooked.
as for your IAC code check your wiring.
Old Sep 24, 2005 | 04:34 PM
NA EJ1's Avatar
Default Re: enigne swap from hell... (BuddhaSiR)
checked and rechecked several times but no solution...anything else?
Old Sep 25, 2005 | 06:47 AM
NA EJ1's Avatar
bump
Old Sep 25, 2005 | 02:53 PM
NA EJ1's Avatar
ttt
JDM_cencal
13
Mar 27, 2017 06:29 AM
Michael Nguyen
Sep 30, 2012 05:37 PM
Vindicator9000
May 3, 2008 05:29 PM
h22jdm
Aug 21, 2007 04:12 PM
CiviCVuE
Mar 2, 2007 11:05 AM
