crank pulley
with the lower cover on, when i slide the crank pulley on, should the crank pulley stick out about 1/2 cm from the edge of where the timing gear, balance gear, and crank pulley sit on, the crank pulley slides on all of the way and touches the balance belt pulley, but sticks out a little bit even when i tighten the crank pulley bolt all of the way, is this normal???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">If this helps for comparison, here it is with just the crank pulley removed. No washers or anything....
yeah thats what mine looks like with crank puelly and lower cover removed, but when i put the crank pulley on it sticks out about 1/2cm beyond the end of the crank even when pushed all the way against the balance shaft pulley
</TD></TR></TABLE>yeah thats what mine looks like with crank puelly and lower cover removed, but when i put the crank pulley on it sticks out about 1/2cm beyond the end of the crank even when pushed all the way against the balance shaft pulley
sorry for offtopic
