what honda motor has a 90mm bore?
Hey all,
I've looked thru some of the specs on the different motors and couldn't find what I was looking. I'm looking for a honda motor that has a 90mm bore either STD or oversize. I know the 3.2 NSX motor has a 90mm bore but I can't do with it what I want. Basically, I have a motor from another manufacture with a 90mm bore and I want to use honda rings on it because I just think they're superior to what's out there. So, is there a motor out there with a 90mm bore? Help me out guys. Thanks.
steve
steve
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevel »</TD></TR><TR><TD CLASS="quote">Hey all,
steve</TD></TR></TABLE>
ummmm none. unless u count resleeved h22 bored to 90 MM
What makes you think that the Honda rings would be the same thickness (1mm,1.2mm 2.8mm) as the pistons you are using? BTW I do know any Honda racers using Honda rings, unless the rules require it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dnbCreative.COM »</TD></TR><TR><TD CLASS="quote">might wanna use the rings that fit your piston knucklehead
</TD></TR></TABLE>wow. what would i have done without that ingenious response.
