Battle of the Imports, Joliet IL......Clay Does an Endo
I talked with clay and his dad quite a while at the event. I got good video footage of his "endo". I think I am correct on what was wrong.
Clay won the event but he probably deserves it after this pass.....Enjoy!
Right Click....Save As
http://sohchonda.com/ipw-web/g...y.wmv
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo »</TD></TR><TR><TD CLASS="quote">doesnt work.</TD></TR></TABLE>
Fixed dawg....Gees...
Damn that would be scary
. What software is used to make vids like that? I see them quite often (Blue screen w/ text then vid and then closing text)?
Phil
. What software is used to make vids like that? I see them quite often (Blue screen w/ text then vid and then closing text)?Phil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic »</TD></TR><TR><TD CLASS="quote"> liberty gears ? </TD></TR></TABLE>
Yes, I believe liberty but I will let Clay confirm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef »</TD></TR><TR><TD CLASS="quote">Damn that would be scary
Phil</TD></TR></TABLE>
This was a simple (quick) Windows Movie Maker. I usually use Vegas Video or Adobe Premiere however.
. What software is used to make vids like that? I see them quite often (Blue screen w/ text then vid and then closing text)?Phil</TD></TR></TABLE>
Thanks again for the video, still cant believe how lucky we were last weekend, things just were not going our way, a second back to first shift at 80mph isnt what I was expecting, we have been having problem with the gear selector inside the trans since we install the G-force shifter, bending the gear selector in Memphis not allowing a fourth gear shift, and this weekend we ended up braking it, allowing the trans to shift to first instead of third, from our data the engine turned well over 15,000rpms!! and the engine is still alive, when the car came back down the engine was still running, but I noticed it had no oil pressure, later to find, the oil sending unit was broke of the mounting bracket. We checked everything over, and repaired the trans issue, but we didn't have a Fourth gear, so we decided to go ahead and give Bisi a run at least to the 1/8th mile, and see how things went.. In the finals Bisi had axle troubles, allowing us a easy win, we ran a 10.61 without a Fourth gear. Again I want to say thanks to Bisi and his team, for all the help, and my team this weekend, because without these people this wouldn't have been possible... Also sorry Bisi for cutting another light on you in front of your girlfriend
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Dam, thats crazy...
to the Sloans... his dad has helped me out before, very cool guy.
