just changed clutch. do i need to bleed it?
Old Sep 24, 2005 | 07:33 AM
the.hamburglar's Avatar
Default just changed clutch. do i need to bleed it?
if so, what kind of clutch fliud should i use?
Old Sep 24, 2005 | 07:38 AM
mike93eh
Guest
Posts: n/a
yes you need to bleed it. use brake fluid.
Old Sep 24, 2005 | 07:51 AM
Default Re: (mike93eh)
why would i need to bleed it? it feels fine. what kind of brake fluid?
Old Sep 24, 2005 | 07:53 AM
92HatchB16's Avatar
Default Re: (the.hamburglar)
You are supposed to bleed the clutch after you change it. Use DOT 3 brake fluid
Old Sep 24, 2005 | 07:58 AM
Default Re: (92HatchB16)
would that take away some of the chatter in first gear when im engaging it?
Old Sep 24, 2005 | 08:01 AM
92HatchB16's Avatar
Yes, it probably will, and the chatter could just be because it is brand new. Just go easy on it for a while and it will go away.
Old Sep 24, 2005 | 08:09 AM
CardDealer's Avatar
Banned
Default Re: just changed clutch. do i need to bleed it? (the.hamburglar)
Modified by CardDealer at 4:31 PM 11/16/2006
Old Sep 24, 2005 | 08:25 AM
Luserkid's Avatar
Default Re: just changed clutch. do i need to bleed it? (schlit)
You could be getting chatter because its not broke in yet. Once its broke in that usually goes away.
Some cars i do need to be bleed others dont.
Old Sep 24, 2005 | 08:40 AM
mike93eh
Guest
Posts: n/a
yes but go ahead and bleed it anyway. its not like its a big deal to bleed it.
Old Sep 24, 2005 | 09:11 AM
built562's Avatar
you dont need to bleed it unless you opened up the lines.
its like bleeding the brakes when you only change the pads, you dont need to unless you opened up the caliper lines.
and yes you need to break in the clutch, also what type of clutch did you get, if you get a harsh clutch the chatter might be normal
Old Sep 24, 2005 | 09:17 AM
ThatsMyEG's Avatar
Default Re: (built562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 &raquo;</TD></TR><TR><TD CLASS="quote">you dont need to bleed it unless you opened up the lines.</TD></TR></TABLE>
Thats correct....
I would put a 1000 miles on it before you start racing around shift light and dont drop the clutch.. This will make your clutch last alot longer..
Old Sep 24, 2005 | 05:36 PM
Default Re: (ThatsMyEG)
i got the exedy stage 2 cermetallic. i never removed any lines so thats why i was asking why i had to bleed it? it didnt make sense. but im going to anyways because the fluid looks a little nasty
gokblok
Nov 15, 2016 03:13 AM
maxogsr
Mar 29, 2010 06:43 AM
in-n-outboy
Sep 29, 2004 09:40 AM
wizurd
Mar 15, 2002 05:37 PM
Malice
Feb 4, 2002 08:16 AM
