First time w/ Stainless Steel.... TIG.
Old Sep 24, 2005 | 04:14 AM
tONE.steR's Avatar
* B A N N E D *
Default First time w/ Stainless Steel.... TIG.
It's been a while since I've touched a TIG machine.. I usually do mild steel and aluminum.
Decided to practice on some stainless trying to keep the color as well as keeping the uniformity/penatration of the weld, overheated a bit at the end.
The other end of the weld I was trying to keep it small and deep into the joint.
3/32" metal, 1/16" rod and tungsten 18-19psi or Argon.
Old Sep 24, 2005 | 07:07 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: First time w/ Stainless Steel.... TIG. (Vita-Soy)
Looks really good considering its been a while since youve done it . Like you said...its a little hot at the end of the weld. Turn it down a tad and slow down a little more at the sides to get better penetration(looks like a little undercut on the smaller weld...but i may be the pic). Also ive found that using 20-22psi of gasflow gives better penetration and better color on stainless of that thickness. Good job man
Old Sep 24, 2005 | 02:31 PM
tONE.steR's Avatar
* B A N N E D *
Default Re: First time w/ Stainless Steel.... TIG. (sCeRaXn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sCeRaXn &raquo;</TD></TR><TR><TD CLASS="quote">Looks really good considering its been a while since youve done it . Like you said...its a little hot at the end of the weld. Turn it down a tad and slow down a little more at the sides to get better penetration(looks like a little undercut on the smaller weld...but i may be the pic). Also ive found that using 20-22psi of gasflow gives better penetration and better color on stainless of that thickness. Good job man </TD></TR></TABLE>
Yea, I'm gonna bump up the argon and maybe get a gas lense too.
Either I need to work faster towards the end of the weld or be easy on the pedal. Its hard for me to work slow though.
Old Sep 24, 2005 | 02:33 PM
ManBearPig4silly's Avatar
It's easier to let off the pedal and yes a lense makes all the differance.
Old Sep 25, 2005 | 02:20 AM
tONE.steR's Avatar
* B A N N E D *
Default Re: (I4sillypwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I4sillypwr &raquo;</TD></TR><TR><TD CLASS="quote">It's easier to let off the pedal and yes a lense makes all the differance. </TD></TR></TABLE>
Yea, I've always heard good things about a lense have yet to try one though.
Old Sep 25, 2005 | 10:43 AM
Default Re: (Vita-Soy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vita-Soy &raquo;</TD></TR><TR><TD CLASS="quote">
Yea, I've always heard good things about a lense have yet to try one though.</TD></TR></TABLE>
You will never go back after you try it (unless you have to fit in a tight spot)
Old Sep 25, 2005 | 03:24 PM
tONE.steR's Avatar
* B A N N E D *
You will never go back after you try it (unless you have to fit in a tight spot)</TD></TR></TABLE>
Gonna pick one up this week.
Old Sep 25, 2005 | 05:03 PM
Engloid's Avatar
OG Fabricator
Just Friday at work, I learned something about gas lenses. One of the night shift guys had used my welding machine on Thursday night and had taken off my gas lens and put on a regular collet body. He left my parts in the little drawer on top of the machine, along with a few others I had in there.
I put the torch together and suddenly, the nice gold color I had the day before went to ****. I checked the gas, checked for any leaks, debris in the gas lens and all kinds of stuff. I even swapped out the gas lens. Finally, I put the regular cup back on and without a gas lens it welded fine. I then put on an old WELDCRAFT gas lens and it worked fine. I then put the new generic POS on that the company had bought (I brought in the weldcraft) and the weld went to **** again.
I suspect that the screen in the generic lens was coated with something that wasn't very friendly to the heat. Either way, I learned that gas lenses are not all the same.
I may post up a pic in a few in another thread of some of the welds...I'm a bit bored.
Old Sep 25, 2005 | 11:40 PM
tONE.steR's Avatar
* B A N N E D *
Default Re: (Engloid)
What would you recommend?
Old Sep 26, 2005 | 12:11 AM
JoJO...'s Avatar
not bad at all...
looks good
Old Sep 26, 2005 | 08:07 AM
Good to know Engloid. I think mine are weldtec or something like that.
Turboteg27
Apr 20, 2012 07:27 AM
scootibum
Acura TL, RL & ZDX
87
Sep 5, 2009 03:18 PM
wade
Welding / Fabrication
23
Jan 27, 2008 09:32 AM
whitelightning
Jan 27, 2003 01:56 PM
