removing ABS.... Is it worth it?? NEED HELP PLEASE
Old Sep 24, 2005 | 01:36 AM
compwc18's Avatar
Default removing ABS.... Is it worth it?? NEED HELP PLEASE
I have a 95 Civic EX Coupe, that has the factory rear disc brakes which means it also has ABS... I don't want to have ABS, because I want to clean up my car and my engine bay completely... What all is necessary to get rid of the ABS? Can I jsut rip out all the line and wires? Please help with this ASAP.... Would like to get this done... Please post pics or any helpful links or pictures.... Thank you....
Old Sep 24, 2005 | 02:43 AM
taney's Avatar
i think the right way to do it is get a hard lines off a non-abs 92-95 because the hard lines will be different when you run a non-abs prop valve .. 2 going in and 4 going out .. and get a 40/40 non-abs prop valve off a DA .. and you can remove the abs unit ..
Old Sep 24, 2005 | 02:48 AM
The_Todd's Avatar
Farts in the shower
Default Re: removing ABS.... Is it worth it?? NEED HELP PLEASE (compwc18)
If you're using your car for track and drag only then take out abs, if you want safety and use your car for daily driving don't sacrifice it for 'looks'.
Just my 2 cents.
Old Sep 24, 2005 | 05:19 AM
T-RO's Avatar
If youre serious I DO want ABS. I would take off and swap all the parts from my non-ABS hatch and trade for your ABS parts. PM me if you want to talk about it.
get RIGHT
Suspension & Brakes
Jun 23, 2009 11:59 PM
bigsnorlax
Apr 3, 2009 08:06 PM
j_dee1st
Jan 18, 2009 09:11 PM
skiptomylou
Apr 13, 2006 06:09 AM
