mini-me killling me..
Old Sep 24, 2005 | 01:15 AM
mr. vang's Avatar
Default mini-me killling me..
okay heres the thing..got my mini me done..y7 bottom end y8 head..got every thing hook up, plugged up, filled with all fuilds and started the motor. it idles fine but when i give it alitttle gas the motor dies out..even on a cold start and at operating temp...if i instantly give it gas the motor will die out..mods are i/e, str fuel rail, walbro 255..help please..motor is in a obd2 car..using stock p2p ecu..
Old Sep 24, 2005 | 05:40 AM
the jdmchop's Avatar
Default Re: mini-me killling me.. (jdm_whore)
any codes?
Old Sep 24, 2005 | 08:24 AM
VTECVillain's Avatar
Is your timing set properly? Do you have a FP gauge to check your fuel pressure? The 255 pump is overkill for the setup and it could be flooding out/super rich altough it shouldn't be if you have the pressure adjusted properly.
Old Sep 24, 2005 | 09:11 AM
mr. vang's Avatar
Default Re: mini-me killling me.. (American Deathray)
no codes, i do have fuel preasure gauge and regulator...the 255 pump was in there from my recent turbo setup and i sold my stock one..fuel pressure is set at stock..cant check my timing no timing gun..
Old Sep 24, 2005 | 10:35 AM
Kendall's Avatar
check your cam timing, not your ignition timing. You can always loosen the dizzy and rotate it while the car is running to find the spot where it runs best, but it won't run worth a **** at all with the cam timing off.
Old Sep 24, 2005 | 03:15 PM
mr. vang's Avatar
Default Re: (Kendall)
i already tried doing that..tried it at different spots to see what worked best..still ran the same..
Old Sep 24, 2005 | 06:48 PM
Default Re: (jdm_whore)
Take off the upper timing cover and rotate the motor to TDC and make sure the timing marks are aligned properly.
Old Sep 24, 2005 | 10:17 PM
mr. vang's Avatar
Default Re: (American Deathray)
did that like 30 times..going to redo timing tomorrow.. see what happens
Old Sep 25, 2005 | 12:04 AM
2.SloEK's Avatar
Same thing with mine but im totally stock....
Old Sep 25, 2005 | 10:46 AM
mr. vang's Avatar
Default Re: (2.SloEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.SloEK &raquo;</TD></TR><TR><TD CLASS="quote">Same thing with mine but im totally stock....</TD></TR></TABLE>
what did you do to get it fixed..
Old Sep 25, 2005 | 12:20 PM
where did you get the motor?
did you do it yourself? the head swap i mean?
Old Sep 25, 2005 | 01:07 PM
aquabob89's Avatar
* B A N N E D *
Are you getting air? Do you have vacuum leaks?
Old Sep 28, 2005 | 12:35 PM
mr. vang's Avatar
Default Re: (jdmchop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmchop &raquo;</TD></TR><TR><TD CLASS="quote">where did you get the motor?
yeah i did it my self...
Old Sep 28, 2005 | 12:37 PM
mr. vang's Avatar
Default Re: mini-me killling me.. (aquabob89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aquabob89 &raquo;</TD></TR><TR><TD CLASS="quote">Are you getting air? Do you have vacuum leaks?</TD></TR></TABLE>
im pretty sure theres no vaccum leak..
bracket 4 life
Honda CR-V & Element
Apr 18, 2011 09:25 PM
punisher003
Dec 24, 2008 04:37 PM
TURBODEEZ
Oct 11, 2005 02:38 PM
mahatma
May 6, 2005 11:46 AM
VtecDA9
Feb 12, 2003 03:06 AM
