CRANK removal h22a prelude 1999
Old Sep 23, 2005 | 11:42 PM
mark_30_2's Avatar
Default CRANK removal h22a prelude 1999
hi,
i need to take out my crank: does the oil pump need to be removed to do this?
if so...
do you have to remove the balance shafts to remove the oil pump on a H22A
i did a search but couldn't get a answer.
i got as far last nite removing everything else like theCam belt etc gearbox/ flywheel, oil pan/pick-up/baffle but i just wanted to check about the oil pump, i just wanted to check with someone, (i've ordered a helms manual but i'm waiting for it to be shipped), cos' was reallly hoping to carry on. just need a quick yes/no thanx
Old Sep 24, 2005 | 12:57 PM
LudeyKrus's Avatar
No and no.
Pull the bottom off the motor, remove the side plates, and the crank will drop out after being unbolted from the saddles.
The oil pump will come out without taking out the balance shafts.
jonny11844
Oct 15, 2013 01:11 PM
Omegax10
Mar 3, 2012 09:59 PM
umair
10
Feb 19, 2009 03:30 PM
NSTY Z33
Aug 4, 2004 10:55 PM
bb6h22a
May 30, 2002 03:20 PM
