XSi axles different from 1992 GSR?
so i just got my motor swapped in. starts beautifully and so on. except the axles i got are appanently too long. they are the XSi one with the first gen motor from hmotorsonline.com. when installed my car makes a thump and the axle rattles vigorously. i know it weird. the other side is fine. this is the driver side that is ******* up. ...any ideas?....so is the USDM 92 GSR axles different from the XSi oness? ill check it out tomorrow. the motor is a b16a with place mounts and dc headers. everythiung else is completely stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FakeJDMEF8 »</TD></TR><TR><TD CLASS="quote">so i just got my motor swapped in. starts beautifully and so on. except the axles i got are appanently too long. they are the XSi one with the first gen motor from hmotorsonline.com. when installed my car makes a thump and the axle rattles vigorously. i know it weird. the other side is fine. this is the driver side that is ******* up. ...any ideas?....so is the USDM 92 GSR axles different from the XSi oness? ill check it out tomorrow. the motor is a b16a with place mounts and dc headers. everythiung else is completely stock. </TD></TR></TABLE>
ALL Passenger SIDE AXLES FOR 1990-2000 INTEGRA ARE THE SAME.....The driver side axels are different between 1990-1993 and 1994-2000. You can use the 1994-2000 passenger side axles on 1990-1993 trannies provided you change the seal and use the intermediate shaft from a 1994-2000.
aser1z
Mar 24, 2007 09:26 PM
