no sound from speakers
Old Sep 23, 2005 | 09:24 PM
ecovillain's Avatar
Default no sound from speakers
today my speakers stopped working.
i was driving around listening to some music, and i pulled up to stop at a park. as of late my subs havent been working all that great, so i inspected the amp wiring.
the ground wire to my amp was not perfectly 'in' its slot on the amp, so i took it off with a screwdriver and screwed it back in correctly. car was off, HU was off, battery was still connected.
i went to go turn everything on and test it out, and i get no sound from anywhere.
subs dont work, front speakers dont work. everything WAS working correctly before, for almost 6 months, no issues.
the fronts are connected to the factory wiring, so its not an amp issue. i reset the headunit and i still got the same thing. keep in mind that the headunit still works and i can press buttons and adjust the volume and such, but no sound. both radio and cd are MUTE.
please help!
Old Sep 24, 2005 | 02:22 AM
ecovillain's Avatar
Default Re: no sound from speakers (ecovillain)
okay update:
it turns out there IS sound from the speakers...but very, very little. i can only hear things when the volume is above 29 (it goes to 33). when at the highest setting, things sound distorted like they would at that high of a volume level, but the sound is very quiet.
what makes speakers super dim/quiet?
Old Sep 24, 2005 | 12:56 PM
fcm's Avatar
fcm
Old Fart
Do you have rear speakers? Where is the fader set to? And the sound you do get, is it all highs, not just no sub bass, but no bass/mid bass at all? 94
Old Sep 24, 2005 | 01:36 PM
ecovillain's Avatar
Default Re: no sound from speakers (fcm)
no rear speakers...just fronts and then a two-channel amp and two subs.
as far as i can tell, the subs arent working at all, and the fronts produce a tiny amount of (distorted) sound at very high volumes. everything is at zero; i reset the headunit (clarion dxz545) and havent touched anything since.
Old Sep 24, 2005 | 08:45 PM
lude_behavior's Avatar
Sounds like your grounding out somewhere. Check to make sure there isnt a speaker terminal or speaker wire pinched somewhere because if the actual wire itself touches ground it will cause that.
Old Sep 25, 2005 | 12:15 PM
fcm's Avatar
fcm
Old Fart
Default Re: no sound from speakers (lude_behavior)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude_behavior &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like your grounding out somewhere. Check to make sure there isnt a speaker terminal or speaker wire pinched somewhere because if the actual wire itself touches ground it will cause that.</TD></TR></TABLE> Ditto that. Although that does not explain why the sub is not working, I would unplug the sub RCAs, [at the HU] and check that no pre-amp outputs are shorted out, behind the Hu. 94
Old Sep 26, 2005 | 09:52 AM
ecovillain's Avatar
alright everyone, thanks for your help. it was a wire grounding out...the remote turn-on lead and the ground wire were contacting each other at the terminals on the amp. it is fixed!
Outlaw-Hondaz
Audio / Security / Video
Apr 7, 2011 03:55 PM
ahobbs
Jun 14, 2009 07:17 PM
TheTealHatch
23
Oct 11, 2006 08:05 PM
Jonathan_ED3
Oct 6, 2003 10:40 AM
Liquidgsr
Mar 14, 2003 10:56 PM
