What should be done after installing Brembo rotors on 00'' si?
Old Sep 23, 2005 | 08:52 PM
klomast3r's Avatar
Default What should be done after installing Brembo rotors on 00'' si?
should U bleed it, if so, how? Im just assuming the logics.
Im sure someone had them installed before with success.
Old Sep 23, 2005 | 09:07 PM
mugen mj5's Avatar
From: Where the shooting range is on the streets of LA, CA.
Default Re: What should be done after installing Brembo rotors on 00'' si? (klomast3r)
well i installed mine on my ek and didnt really bleed nothing... its like i didnt even change my rotors... untill i notice the better braking!!!! man i love my rotors.. hahaha.. but thats what i did just changed them and really didnt have to do anything else special... just dont forget to open the break fluid cap when installing... thats what i did.. then close it back when your done...
Old Sep 23, 2005 | 09:08 PM
1995Ex_Sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klomast3r &raquo;</TD></TR><TR><TD CLASS="quote">should U bleed it, if so, how? Im just assuming the logics.
Im sure someone had them installed before with success.</TD></TR></TABLE>
You should really get a manual or something. You shouldn't have to bleed unless you let air into the system somehow.
Old Sep 23, 2005 | 10:16 PM
undertheradar's Avatar
Default Re: What should be done after installing Brembo rotors on 00'' si? (1995Ex_Sedan)
Yup...no need to bleed anything unless you're changing lines or fluid.
Old Sep 23, 2005 | 10:22 PM
EL Vap133's Avatar
Default Re: What should be done after installing Brembo rotors on 00'' si? (undertheradar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undertheradar &raquo;</TD></TR><TR><TD CLASS="quote">Yup...no need to bleed anything unless you're changing lines or fluid.</TD></TR></TABLE>
Old Sep 23, 2005 | 10:29 PM
Luserkid's Avatar
Default Re: What should be done after installing Brembo rotors on 00'' si? (EL Vap133)
Put them on and drive.
oMek
Jun 9, 2006 12:30 PM
Teglessb18
Oct 7, 2005 10:34 AM
SiRkid
Jan 15, 2004 06:10 AM
gsr camel
Acura TL, RL & ZDX
Dec 29, 2003 08:38 AM
Weston
13
Dec 1, 2003 09:15 AM
