I NEED HELP WITH MSD!
ok.. im a newbie to this.. but i realli need help.. i bout a full msd ignition system for my 95 integra.. i followed the instructions.. but i was so over whelmed with it.. i kinda rushed it.. and i think i might have crossed my wires.. is there a way to tell if i fried my sci box?.. or. n e thing?.. my car wont start,, it juss u hear the starter.. tryin to catch.. and heres a couple pics.. can anybody tell me what each pronge on the ignition goes to?.. or.. walk me step by step to fix my problem???
where does that stray black and yellow wire go to??
and can anyone walk me through my distributor wiring?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">Why in the name of God did you buy an MSD setup? Are you even aware of how awesome the stock Honda ignition is?</TD></TR></TABLE>
are stock honda ignition that awesome? can they handle a turbo setup? maybe thats y he's upgrading??
i'd like to know
i'd like to know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Palmy Blue »</TD></TR><TR><TD CLASS="quote">
Aparently they dont have multiple spark...
As for the poster... is the main coil wire supose to look like that???</TD></TR></TABLE>
Yea, I was thinking the same thing. That looks F'd up.
to a shotty install.
well, you effed up your distributor, and your coil wire is horrible. Why on earth did you connect those wires to the ignightor?. The instructions are simple and available on msd's website
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeroz »</TD></TR><TR><TD CLASS="quote">are stock honda ignition that awesome? can they handle a turbo setup? maybe thats y he's upgrading??</TD></TR></TABLE>
They don't have multiple spark capabilities in stock form, but the spark is surprisingly consistent all the way up until about 8000 rpms. Even on low to moderate boost applications there is no need to worry about upgrading until you start closing in on the 300 whp mark. Usually a good set of plugs will solve most of your ignition maladies unless you start dealing with fully built motors. Hell, most fully built motors I've seen are still using a stock ignition with nothing but upgraded plugs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dazed teG »</TD></TR><TR><TD CLASS="quote">i followed the instructions.. but i was so over whelmed with it.. i kinda rushed it.</TD></TR></TABLE>
There was your first mistake.
http://www.msdignition.com/pdf...3.pdf
Maybe that will help you, this msd is very easy to install, just a few wires to hookup. Just make sure you put the rubber boot on that coil plug, don't want the spark jumping around, the kit should've come with the boot for the coil wire. Also, I've noticed that even if you fried your msd box the car should still start, because it will bypass the box and go off the stock ignitor. Had that happen in my crx, engine started with the msd main power and ground disconnected, scared the hell outta me when it fired, was trying to prime the engine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">They don't have multiple spark capabilities in stock form, but the spark is surprisingly consistent all the way up until about 8000 rpms. Even on low to moderate boost applications there is no need to worry about upgrading until you start closing in on the 300 whp mark.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaxsimike »</TD></TR><TR><TD CLASS="quote">a stock honda ignition can handle somewhere around 300 hp. the msd does have the multiple spark though.</TD></TR></TABLE>
way to requote what kendall already said
ok well yea i made a mistake.. and i tried to do the stuff myself.. u kno.. shiet happens sumtimes.. and i got love for the people tryin to help me,.. but atleast gimme some props on tryin new things on my car.. its straight though criticism doesn't bother me too much.. would n e one have the wiring diagram on a b18b1 ignition (inside the distributor box)?
yea.. tru.. i'll buy u guys sum.. shrimp fried rice if u guys can give me the wiring diagram of the ignition module.. and.. all that other shiet under the distributor cap.. the colored insulation came off.. typical for me
superhatchbackbros
Oct 17, 2006 08:17 AM
Crimson_Tide
Apr 9, 2005 12:21 PM
