97-01 prelude ignition timing obdII-obdI jumper p28 ecu???
Old Sep 23, 2005 | 08:33 PM
sicegcivic's Avatar
Default 97-01 prelude ignition timing obdII-obdI jumper p28 ecu???
is it possible to adjust timing on prelude with p28 & obd1 jumper harness + 5 speed conversion??? car bogs low rpm like it is retarded???? any help appreciated!
thanks
-Don
Old Sep 23, 2005 | 08:53 PM
sicegcivic's Avatar
Default Re: 97-01 prelude ignition timing obdII-obdI jumper p28 ecu??? (sicegcivic)
bump.. also would the fact that the injectors are still obd2 have anything to do with this???? if so how do i fix that problem...resistor box from 4th gen??? or off a civic?? different injectors from obd1 car????
Old Sep 23, 2005 | 09:32 PM
v4lu3s's Avatar
RTFM
change the program.
and you math th resistor box to the injecotrs...not the ecu.
Lemwell Estrera
Oct 11, 2016 11:01 AM
VashTheStampede
Apr 13, 2016 08:41 AM
beelzebub
Mar 5, 2006 07:55 PM
integrakev78
Nov 15, 2004 04:08 AM
