zc vtec swap won't start
Old Sep 23, 2005 | 07:40 PM
d16vtecx's Avatar
Default zc vtec swap won't start
i have an 88 crx hf with a jdm sohc zc vtec(d16z6)
just finished installing it
i used crx si wire harness and y8 IM
i have a code 6(ECT)
water coolant temp
is this the one on the head or the one on the thermostat housing
i extended the si thermoswitch that was on the back of the obd-0 block to the obd-1 plug on the thermostat housing
it does not and has never started
stock pm8 ecu flashes code 6 and code ten(because of dangling iat)
my stock pr3 ecu flashes sixteen short blinks
i know im reading the pm8 right but i may be wrong on the pr3
i dont think these codes would keep it from starting
also i havent wired the vtec or vctec oil pressure yet
sorry for the long *** post been lagging on this swap for months
frustrated in SoCal
Old Sep 24, 2005 | 09:29 AM
d16vtecx's Avatar
Default Re: zc vtec swap won't start (d16vtecx)
bump
Old Sep 24, 2005 | 09:39 AM
CaliforniaHighwayPatrol's Avatar
It is called a mini me swap by the way
Old Sep 24, 2005 | 09:41 AM
jlicrx's Avatar
the Si engine harness is not compatible with 88 HF chassis harness
Old Sep 25, 2005 | 11:02 AM
d16vtecx's Avatar
Default Re: (JDM VTACK)
actually it's not a mini me buddy
zc vtec=jdm d16z6
Old Sep 25, 2005 | 11:03 AM
d16vtecx's Avatar
Default Re: zc vtec swap won't start (jlicrx)
so should i get an 88 si harness or can i modify the 90 harness to work
thanks for the help
Old Sep 25, 2005 | 11:06 AM
2point2's Avatar
always use the engine harness that came with the chassis! Modify to fit.
1990crx
11
Jun 9, 2007 06:15 PM
pyro_freak8
Mar 25, 2004 01:30 PM
pyro_freak8
10
Mar 24, 2004 12:10 PM
slowman
Jun 16, 2002 08:27 PM
