92-96 Fog light Relay Harness Questions.
Old Sep 23, 2005 | 06:41 PM
OEM_ASSASSIN's Avatar
Default 92-96 Fog light Relay Harness Questions.
From searching, it seem that I do not need the harness and can just plug the fog relay into the brown plug. The harness is just needed to mount the relay.
I do not have the honda relay. I just have a automotive 4 pin from Radio Shack.
pins are 30, 86, 87, 85
Which pins go into which hole on the brown plug?
Also, I read that the relay needs to grounded to the chassis, but shouldn't one of those female ends on the brown plug be a ground for the pin?
*EDIT* one more question.
I have a 92. I found the green plug, which I believe is for the switch. Once I have the relay hooked up all I need to do is jump hole 5 to hole 9 to achieve ghetto switch status?
Thanks,
OEM
PS. I searched and have read about every thread I could find on this on Honda-Tech. None of the threads I found gave me a clear answer. I just want to know for sure before I attempt to install the relay. I even joined and paid for preludeonline to see if they had a write up, but it still won't let me see any threads
Old Sep 24, 2005 | 07:38 AM
bump
Old Sep 24, 2005 | 04:33 PM
ttt still can't log on to po.com
Modified by OEM_ASSASSIN at 6:22 PM 9/24/2005
FIGURED IT OUT. I WILL MAKE A WRITE UP SINCE I DID NOT SEE ONE BEFORE.
Modified by OEM_ASSASSIN at 7:00 PM 9/24/2005
Digitalis
Apr 27, 2015 11:08 AM
sirEGhatch
Feb 9, 2010 12:08 AM
Schultzie
May 1, 2007 04:25 AM
popRAWvtec
Nov 20, 2006 03:32 AM
pre1udekid
Aug 3, 2004 06:00 PM
