1990 Civic Engine Swap Question
Old Sep 23, 2005 | 03:57 PM
Wolfgang5884's Avatar
Default 1990 Civic Engine Swap Question
My friend has a 1990 Civic Sedan EX. He has a 1997 Civic DX engine available. The engine code for the 97 is D16Y7 I believe. The question is, can he swap the engine with little to no modification? Another question is, can he use his 1990 transmission? Also what would he need for the swap? Thanks in advance I don't have much time to look for the info myself.
No lame search button answers I tried.
Old Sep 23, 2005 | 05:06 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: 1990 Civic Engine Swap Question (Wolfgang5884)
yes it'll swap wiring for differnt obds other then that plug and play he can use his 90 tranny
Old Sep 24, 2005 | 02:08 PM
Default Re: 1990 Civic Engine Swap Question (Ace$nyper)
thanks, buddy. My knowledge of early gen civics is not that good.
Old Sep 24, 2005 | 02:32 PM
jack_attack's Avatar
the tranny will bolt up nice and good just gotta use a 90 clutch and a 97 pressure plate unless you have the 90 flywheel as for the wiring just convert both to obd1 and everything else should just bolt right in
Old Sep 24, 2005 | 02:46 PM
g-ride-si's Avatar
why is he swapping? Dont those engines have about the same hp and tq? Assuming the ex had d16a6.
Old Sep 26, 2005 | 11:49 AM
Default Re: (g-ride-si)
His original engine has over 300k miles and is just falling apart. He can get the 97 civic motor which has a little over 60k miles for just 250 bucks.
stewartcannon
36
Oct 24, 2015 03:30 AM
ef 4dr
Jan 8, 2008 11:36 AM
dawrenn
Jul 3, 2005 01:54 PM
delsolitude
Jun 24, 2005 09:23 PM
