speaker wiring question
I got a 00 Si and I wanna put in some new speakers but it has the oem honda connectors, which wires r the + -. if it was jus two wires i would try but there is 4 i think cause it has the honda tweaters also.
You could by a speaker harness connector, they make them for Honda's, they are like 7.99 a pair at Circuit City. Basically it takes like 30 seconds to hook up the speakers, because the adapter is just like the factory plug in there.
If you do have tweeters in the car and plan upgrading to a component system a speaker harness will do you no good, because you are gonna have to wire up the crossover anyway.
the car has the stock honda tweeters, it seems like they r wired into the door speaker. im also curious on whats + and - so i can hook up the bass blockers and what not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ian22 »</TD></TR><TR><TD CLASS="quote">the car has the stock honda tweeters, it seems like they r wired into the door speaker. im also curious on whats + and - so i can hook up the bass blockers and what not.</TD></TR></TABLE> This should help http://www.installdr.com/Harnesses/HA-Wiring.pdf
94
94
With your civic you can just replace the woofer in the door and still maintain the factory tweeters, just buy the speaker harness and un hook the one off of the woofer. But if your hell bent on determining which one is the appropriate color you can pop the speaker by throwin a few volts through it to make the cone actually pop outward or suck inward. Hook up some speaker wire to a batter, one to the negative side and one to the possitive then touch the other ends to the speaker terminals. If it pops outward, the speaker is in phase meaning you found the correct + and -. If it sucks inward its out of phase so reverse it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude_behavior »</TD></TR><TR><TD CLASS="quote">With your civic you can just replace the woofer in the door and still maintain the factory tweeters, just buy the speaker harness and un hook the one off of the woofer. But if your hell bent on determining which one is the appropriate color you can pop the speaker by throwin a few volts through it to make the cone actually pop outward or suck inward. Hook up some speaker wire to a batter, one to the negative side and one to the possitive then touch the other ends to the speaker terminals. If it pops outward, the speaker is in phase meaning you found the correct + and -. If it sucks inward its out of phase so reverse it.</TD></TR></TABLE> Although you are right on everything except when you say the speaker is in phase or out of phase, a speaker can't be in or out of phase with itself, only in conjunction with other speakers, output from an amp is not DC like a batt. it is AC, so it does not matter how you wire the speaker pos. to pos. and neg. to neg. or pos. to neg. and neg. to pos. as long as all the speakers are wired the same.
Wiring one side pos. to pos. and neg. to neg and the other side pos. to neg. and neg. to pos., that would be out of phase doing the same thing to two subs running off one channel would also be out of phase.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ian22 »</TD></TR><TR><TD CLASS="quote">not the wiring diagram for the radio connection, the plugs for the speakers, what colors r for wat?</TD></TR></TABLE> are the colors not the same at the speakers? If not test the way lude-behavior recommends, it will tell you which term. is pos. and in so doing what wire is pos. or you can just pick one side on the plug and do the same on all the speakers, it makes no diff. as long as they are all the same
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by That Sob »</TD></TR><TR><TD CLASS="quote">FCM how come i cant view that link..its asking for user name and pass???</TD></TR></TABLE>I'm not sure try http://www.installdr.com
94
94
Dead CIVIC
Audio / Security / Video
Jan 23, 2015 06:24 PM
crvsam
Aug 29, 2008 07:07 PM
