Greasin' up my axles
Old Sep 23, 2005 | 08:01 AM
Doom325's Avatar
Default Greasin' up my axles
It turns out that I need a passenger side and drivers side cv boot and I was wondering whats the best way to regrease my axles if I can't afford to replace the boots? Can I just go get some axle grease from autozone and grease the axle from where the cv boot is ripped? Any help is appreciated
Old Sep 23, 2005 | 08:11 AM
2lude4u's Avatar
Default Re: Greasin' up my axles (Doom325)
You should replace the boot, not just stick more grease in through the rip.
I've replaced boots before & it is an absolute pain. It's easier and much less time consuming just to buy new axles. They aren't very expensive and it saves you a lot of time (time is $).
Old Sep 23, 2005 | 08:15 AM
Doom325's Avatar
Default Re: Greasin' up my axles (2lude4u)
Of course I would do that if I had the cash.... Right now i'm looking for someway to make sure my axles don't bite the dust (if they haven't already) until I can have the money to fix it. Does anyone know of a way to regrease teh axles?
Old Sep 23, 2005 | 08:29 AM
2lude4u's Avatar
If you're just trying to get by then just buy some grease, put it in through the cracks (grease gun would make it easy), then depending on how big the cracks are use zip ties or something (maybe a good flexible glue) to try and close the cracks as needed.
P.S. I have a pair of H22 axles (not sure what motor you've got) with near perfect boots that I'd be willing to sell for $90 shipped if you want them.
Old Sep 23, 2005 | 08:58 AM
Doom325's Avatar
H23 But thanks anyways, i'll defintely do what you suggested
Old Sep 23, 2005 | 10:00 AM
staticrex's Avatar
temporary fix would be to do what you mentioned but not recommended. But it may be ok for a while.
Old Sep 23, 2005 | 11:24 AM
LudeyKrus's Avatar
FYI: H23 axles and H22 axles are interchangable, assuming they're both 4th gen axles.
Temporary fix? Go to Autozone and get a can of Valvoline's multi-purpose grease. It is labelled as being fine for import automotive axles. IIRC, it's in a blue/purple/silver can.
Stuff a crapload of grease into the boot without making the tear worse.Then, take a bunch of duct tape and wrap that sucker like your jimmy when gettin with a cheap asian hooker......
Cheap? Yes. Ghetto? Yes. But that's what you asked for.
prostreetonline
Jul 7, 2006 04:13 PM
b18bfreak
Aug 2, 2004 10:05 AM
jdmskin
Oct 13, 2003 01:04 PM
Prelussion
Nov 15, 2001 12:51 PM
