Aem Ems for 1995 to 2005 nsx
I have developed a engine management system for the 1995 to 2005 nsx. It will consist of a modified Aem ems and a custom Jumper harness tailored to your year of car. This system will be all plug and play with no wiring modifications that are nessesary. This system will have have full tunability over the engine as a normal Aem Ems would have. Systems are in production now and will be ready in two weeks. For the Custom Jumper harness and modifyed Aem ems it will $2395. There are only two options the car looses
The coolent temperature guage becomes non operational and the factory traction control is non opp. But there is a fix for both. In the aem you may set it to turn on the check engine light if the car would to start over heat. And traction controll may be setup using the Aem Ems
