96-00 Civic suspension interchangeable with Del Sol?
Old Sep 23, 2005 | 06:10 AM
Fuster_Cluck's Avatar
Default 96-00 Civic suspension interchangeable with Del Sol?
What all parts are interchangeable between the two?
Main thing I am curious about is the suspension.
EK seats bolt into a sol and vise versa?
Old Sep 23, 2005 | 09:28 AM
B96v6's Avatar
Default Re: 96-00 Civic suspension interchangeable with Del Sol? (Hybrid93Hatch)
Nope. EG and Del Sol are completely interchangeable. The front suspensions on all 92-00 Civics are the same, but the rears are different (slightly). The only things on the rear you won't be able to swap are the rear shocks and LCA's, unless you want to swap both into your Sol.
If you want to swap seats, only 3 of the 4 holes will line up. You can either swap the seat rails and the seats, or you can extend the hole in the rear inner mounting tab to ghetto rig a bolt into the floorpan. I swapped Civic rails onto my GSR seats to put them into my 98 hatch. Everything lines up now and the seats don't rock back and forth when I turn.
B96v6
Old Sep 23, 2005 | 09:31 AM
SIR-G's Avatar
Default Re: 96-00 Civic suspension interchangeable with Del Sol? (B96v6)
nope not interchangable like what B96v6 said
SLO_EH2
Dec 7, 2008 02:54 PM
VTECdohcter
Aug 28, 2007 01:36 AM
Kevinarich
Apr 11, 2006 07:33 PM
tradesalot
14
Jul 8, 2005 04:40 PM
JJW
Jul 14, 2003 02:07 PM
