I can use this oil pump * Pix*
Old Sep 23, 2005 | 05:51 AM
preludesi93-arg's Avatar
Default I can use this oil pump * Pix*
This oil pump came out of h23 engine with 123 km and with one spun rod
Can i use with other engine ??
Old Sep 23, 2005 | 06:02 AM
PrecisionH23a's Avatar
Default Re: I can use this oil pump * Pix* (preludesi93-arg)
Check the tolerances. If they check out, use it. Personally, I wouldn't use it because it looks pretty worn out. But then again I'm really **** when it comes to these things.
Old Sep 23, 2005 | 06:25 AM
flyrod's Avatar
Default Re: I can use this oil pump * Pix* (PrecisionH23a)
Better is always the enemy of good enough. Are you planning to run the engine in an endurance race, or just a daily driver on a budget? IMHO that oil pump can be used again. I'd clean it up good then polish out some of the rough areas with 600 grit paper. If it turns smooth and is in spec your oil pressure will be fine.
Old Sep 23, 2005 | 06:47 AM
Lewdin' Incognito's Avatar
Default Re: I can use this oil pump * Pix* (flyrod)
You can pick up a new one for ~$180 here:
http://www.hondaautomotivepart...AINER
Personally I would go with new, unless you're strapped for cash/time - it's a risk, but it's up to you whether it's worth it or not.
EDIT: I just looked one up for my car ('92 Prelude), it may or may not be the one you need.
pjr710
Feb 24, 2009 07:05 PM
Grand
May 9, 2005 11:09 AM
10K2HVN
Jul 10, 2003 03:45 AM
One8Hatch
Jan 3, 2002 01:43 PM
