Installing OBD 1 GSR into 90 CRX Si w B16
I am starting to swap out my 4 yr old Pre OBD B16a and install a newer 95 GSR engine and YS1 cable tranny w/LSD
I have bought the OBD 1 conversion harness and am going to be using my Si/B16A wiring harness and add the extra wires for the IAB, 4 wire O2, and re-pin for dissy. My problem right now is injectors? I was told to keep my resistor box I have now and use the GSR injectors??? Has anyone done this swap and what did you do about your injectors?
Help appreciated
Spinney
Help appreciated
Spinney
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spinney »</TD></TR><TR><TD CLASS="quote">My problem right now is injectors? I was told to keep my resistor box I have now and use the GSR injectors??? Has anyone done this swap and what did you do about your injectors?
Help appreciated
Spinney
if you are using the OBD1 GSR injectors, then you do not use the resistor box.
Help appreciated
Spinney
So basically i'd be better off to use my B16A injectors since I'm using the harness and keep the resistor box.
what is involved to using the OBD 1 injector set up?
camo_crx
Jan 24, 2007 09:23 PM
