no pressure on clutch pedal
Old Sep 23, 2005 | 04:21 AM
jaywoodz's Avatar
Default no pressure on clutch pedal
I have a 93 prelude h23 turbo. The other day I was driving, and I noticed that shifting into gears was becoming difficult, and sometimes I wouldn't even be able to put it in gear. Then I noticed that my clutch wasnt full of pressure. It was only engaging about half-way. Before it completely went out, I opened the clutch fluid cap, and pumped the clutch, and it eventually came back to full pressure. I road around for a few more days, thinking that it was fixed, and sure enough it happened again, except this time, a lot worse. I have absolutely no pressure at all, It is pressed to the floor, and stays there. I have to manually reach down there and pull it to me. I don't know what the problem is? Can anyone help?
Jason
Old Sep 23, 2005 | 04:33 AM
flyrod's Avatar
Default Re: no pressure on clutch pedal (jaywoodz)
bleed it, look for leaks.
Old Sep 23, 2005 | 04:59 AM
MileHigh's Avatar
clutch master cyclinder... probably needs to be replaced
check that
Old Sep 23, 2005 | 06:42 AM
SpeedFreak77's Avatar
Default Re: no pressure on clutch pedal (MileHigh)
As MileHigh said it's most likely your clutch master cylinder, and if that is it be sure to replace your slave cylinder also.
Old Sep 23, 2005 | 07:27 AM
Honda Sport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MileHigh &raquo;</TD></TR><TR><TD CLASS="quote">clutch master cyclinder... probably needs to be replaced
check that</TD></TR></TABLE>
you should double check the clutch slave cylinder for leaks also.
Old Sep 23, 2005 | 10:10 AM
bad-monkey's Avatar
Default Re: no pressure on clutch pedal (Honda Sport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport &raquo;</TD></TR><TR><TD CLASS="quote"> you should double check the clutch slave cylinder for leaks also.</TD></TR></TABLE>
yup.
MC, SC, or the lines--but the hydraulic system isn't holding pressure.
Old Sep 23, 2005 | 11:04 AM
LudeyKrus's Avatar
Check the slave cylinder first, it's on the front of the tranny and is right there when you open the hood. Pump the clutch a few times and see if there's fresh fluid on the tranny casing. If not, check under the master cylinder.
Old Sep 26, 2005 | 11:57 AM
redLUDEs2k1's Avatar
had the same problem with mine, just not to that extreme. replaced the master and slave cylinders = all better . have them check out.
civic=goodgasmileage
Honda Civic (2001 - 2005)
Jun 3, 2009 02:33 PM
IgnitionZ05
Dec 8, 2006 11:27 PM
fridayfred3p
Apr 27, 2006 03:11 PM
HiAssHell
Nov 5, 2005 05:04 PM
infamousALLMTR
Jun 30, 2003 11:33 AM
