B20 EG track results
Old Sep 23, 2005 | 01:05 AM
MikeNice's Avatar
Default B20 EG track results
I took my 92 Civic hatchback CX to Lebanon Valley to see where my car was at. I have a JDM B20b w/ GSR tranny, I/H/E/, Skunk2 intake manifold, Crane Stage 1 cams, AEM cam gears (at zero settings), Stock PR-4 ECU, Kumho Ecsta street tires on 14 inch steelies, removed rear seats and spare tire, and little over half a tank.
R/T: ...... .083
60: ...... 2.197
330: ...... 6.065
1/8: ...... 9.309
MPH: ...... 76.37
1000: ...... 12.160
1/4: ...... 14.498
MPH: ...... 94.68
I am pretty happy with my times for a non-VTEC swap, but I am always hearing about how shitty of a track Lebanon is and you will almost always hit 2 tenths faster at Englishtown in Jersey cause its closer to sea level when Lebanon in the mountains. I plan to go again in October with some drag radials to ET next time.
Old Sep 23, 2005 | 03:07 AM
BoOstedEM1's Avatar
Default Re: B20 EG track results (MikeNice)
Good times for street tires...
Old Sep 23, 2005 | 06:09 AM
MikeNice's Avatar
Default Re: B20 EG track results (BoOstedEM1)
Any suggestions or advice to what I can do to get cut down my time for what I have. Thanks in advance
Old Sep 23, 2005 | 09:16 AM
BoOstedEM1's Avatar
Put the radials on and pratice launching...
Old Sep 23, 2005 | 09:42 AM
99lspwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeNice &raquo;</TD></TR><TR><TD CLASS="quote">Any suggestions or advice to what I can do to get cut down my time for what I have. Thanks in advance</TD></TR></TABLE>
I just ran 1 tenth slower at the same mph with the identical swap less the header, gsr tranny, cams, and intake manifold....And I have about 150-200 xtra pounds on board...(dx apposed to your cx) ... I would think your traps would be in the 97-98 mph range...Whats the altitude where you are??
Old Sep 23, 2005 | 02:39 PM
MikeNice's Avatar
Default Re: B20 EG track results (99lspwr)
I raced at Lebanon where the altitude is 653ft. and Englishtown is 131ft. which is probably where I am going next time.
Old Sep 23, 2005 | 05:32 PM
Used2beAb16's Avatar
635 ft of elevation isn't that high
Old Sep 25, 2005 | 02:07 PM
MikeNice's Avatar
Default Re: B20 EG track results (Used2beAb16)
Its alot higher than Englishtown. My friend ran 15.7 at Lebanon with an 92 Si hatch SOHC Vtec and about 2 weeks later ran 15.5 with the exact same ****, even the same oil for god sakes. Temperatures where similar and all that.
Old Sep 25, 2005 | 02:40 PM
B16aEGx2's Avatar
I'm 15 minutes away from Englishtown so I feel it's my home track but it sucks.
It seems like they put alot of time into preparing the track but I always hear about traction issues. As the night goes on it gets worse too, it's too slick, me and my buddies always have this problem.
Also I'm not a big fan of the tires, I used them on 15" Racing Harts and had a best 60ft of 2.4 on JDM B16 I/H/E. [Not very poud of that]
cmasonrun
Oct 29, 2007 05:27 AM
MikeNice
May 9, 2006 04:57 AM
MikeNice
Aug 6, 2005 03:39 PM
Vanilla4215
Sep 28, 2002 06:44 PM
Mike K
Jan 25, 2002 12:15 PM
