ISP foor door EF finally got pic for every one, hopefully will be hit mid 12's
[IMG][/IMG]
Ecut-out
still working on the car, let know what you guys think Thanks
Here is the setup -
RedZone built -
84mm B18A1 block
IBspec Wiseco's 11.3:1
Probe rods
Polished and balanced rotating assembly
ACL Bearings
Type-r oil pump
Fadanza flywheel
RedZone Stage 3 clutch
ctr Transmission
B17A Head ported by RedZone
Super-tech Valves
Super-tech Springs and retainers
Blox Type-B Cams
JG Cam gears
Blox intake manifold Port match
68mm RPM TB port matched
255LPH-HO in-tank fuel pump
Custom header 4-2-1
2 1/2 inch exhaust piping with muffler
Hasport motor mounts w/ hydro to cable conversion
Modified by ISPhuevos at 10:17 AM 9/24/2005
Modified by ISPhuevos at 10:20 AM 9/24/2005
Ecut-out
Here is the setup -
RedZone built -
84mm B18A1 block
Probe rods
ACL Bearings
Type-r oil pump
Fadanza flywheel
ctr Transmission
Super-tech Valves
Blox Type-B Cams
JG Cam gears
Custom header 4-2-1
looks good! i like a clean 4 door ef
nice cutout too.. my friend has / had one on his se-r but hit a sewer cover and tore it out
[IMG][/IMG]
here is a few pics of what it looked like before the above pics
here is isphuvos old car
here is our our other hatch santos car at cmi
here is chino hatch at cmi this year
here is my hatch
Modified by isphatch at 6:02 PM 9/23/2005
Modified by isphatch at 6:05 PM 9/23/2005
here is my hatch
Car is looking hot fella's....Get that thing tuned again and hit that 12....I know you can do it. Luanch that bitch at 7k and you'll get your 60ft.....
cant wait to see the times
