-Partin Honda 89 Crx HF-
Old Sep 22, 2005 | 09:38 PM
CrazyKoreanCrx's Avatar
Default -Partin Honda 89 Crx HF-
Forsale
Goin to be parting my Honda crx 89 hf. I'll have pictures for the parts when I take the motor out.
Apexi Vafc Controller 1Gen SOLD
P-72 Ecu Obd-1 Chipped with a on/off switch Vtec 4600 and Redlines 8700
-Gsr Head Itr Valve Cover, Intake Manifold, Fuel Rail, Injectors, Gsr Throttle Body with TPS and Map sensor, Gsr Exhaust Manifold, Intake Pipe with Filter, and 96-99 Gsr Dizzy Obd-2- SOLD
94-95 Gsr Cat. Converter
94-95 Gsr OBX Test Pipe
99-00 Si Short Block with Gsr Oem Flywheel
90-93 J1 Cable Tranny with Stage One Clutch
90-93 Integra Axles with Intermedium Driver Shaft
Obd-0 to Obd-1 Conversion Harness Jumper
88-91 HCP Motor Mounts with T-Bracket
88-91 B-Series Shift Linkage
99-00 Si Radiator
90-93 Interga throttle cable <----Just added
PARTING THE CAR OUT
89 Honda Crx Hf shell with no motor, front hub swap for b-series, Gr-2 Gas Shocks, Ractive Coil-Over, E.S. Bushing, Fuel Filter (new oem), Wired for obd-1 just need the jumper for the ecu and also I'll include extra wires for the car. (Also remeber its a Crx with rust on it and you're goin to need a new hood. Switch I can get one thats black oem)
-Thanks-
Modified by CrazyKoreanCrx at 8:57 AM 9/26/2005
Modified by CrazyKoreanCrx at 11:19 AM 9/29/2005
Old Sep 24, 2005 | 09:50 AM
Default Re: -Partin Honda 89 Crx HF- (CrazyKoreanCrx)
BUMP BUMP
Old Sep 26, 2005 | 05:58 AM
YEp
Old Sep 29, 2005 | 08:20 AM
Bump
Old Oct 1, 2005 | 08:14 AM
oooo
Old Oct 5, 2005 | 05:25 PM
:mR. PotAtO heaD:'s Avatar
how much 4 the shell?
Old Oct 5, 2005 | 08:39 PM
Default Re: -Partin Honda 89 Crx HF- (Lilstreetracer88)
pm replied and yup
CrazyKoreanCrx
Dec 7, 2005 08:47 PM
b16powwer
Jul 7, 2005 06:13 PM
JohnnieChimpo
16
Mar 18, 2004 12:53 PM
NightHawkC5
Jan 8, 2003 01:22 AM
